can start stop be disables?
UPDATE: My scanner came with software ver 50.16. Today I connected the device to wifi and updated all the software. There were 8 modules software updates totally, including the MB (which quite large...). The latest MB software ver is v50.26. After the update, the User Interface looks totally different (from the original), and very similar to the pictures posted here and youtube's. After the update, I was able to change the setting exactly like your description!!. the whole procedure took 2 minutes!!. So it was the old software version that was not able to communicate with the car... newest version fixed all that!!
juanmor40 (02-28-2024)
Great that it works! I wasn't expecting the difference between v50.16 and v50.26 to be that significant. So anyone buying this (powerful!) tool, make sure to update the software before using it!
Received 1,751 Likes
2016 E350 Sport
Just received the Launch device from amazon. The User Interface is different from the youtube video... anyway, I still figured out. When I clicked on the write coding (from active start/stop to no active), it said code writing "unsuccessful". Not sure what I did wrong. Questions: do I need to register the device before using? or do I need to update software 1st before using? I think the firmware right now is V15.16.....
Anyway, I was able to find the the ECM module, changed active start/stop to "no active." But when I clicked on the write coding (from active start/stop to no active), it said code writing "unsuccessful". Is there a youtube demo on how to do this somewhere?
#32
My scanner came original with software ver50.16, and I had the same issue with "writing unsuccessful". After updated, it went through without issue. I used Diagnostic, then automatic detected the car...etc... Under ECM, variant setting...
Also I didnt need to register the device.
P.S. One more thing.. I connected the device online (wifi) during the coding, dont know if that made any different....
#33
Received 4,374 Likes
It is not always under ECM to delete Start Stop.
I believe it was under Central Gateway N93. Go and check there.
I forgot the details as I was using the Autel some years ago and on older software, and it was not as easy and elegant as the Baby Launch .
Since my Start Stop been gone anyway , I never try it with the Baby Launch when I first got it.
I never register it too, no request by the scanner.
Since we are zero update fee forever, they dont care about registration. They can track the device serial number anyway
History
I do not know what is the ACTUAL meaning of 072, why also there is ECO startstop there ... LOL.
076 is what I choose to kill ECO.
History
#34
Received 1,581 Likes
I used the Mid City Engineering OBD plug-in to disable my ECO Start/Stop. It allows you to turn Start/Stop on or off and remembers the last setting. However, the dongle they send is more than the LAUNCH Creader Elite 2.0 BENZ. Since I never plan to use Start/Stop again, I wish I had known that I could do this with either my Autel or the Creader scanner. Not sure it would make a difference when selling or trading the car.
#35
So does this just enable the "save the last setting" and so I can still freely turn it on and off without plugging in the programming device?
#36
wildta (03-02-2024)
#37
I don’t know how pertinent it may be to the OP, because my main reason for posting is not that the SL63(R232) has a split start button, and that the bottom half of the button is an auto start disable function.
The purpose of my post is to address the combination of autostart, and turbocharging features.
The basics of turbocharging are the proper care and feeding of a turbocharger.
A couple of the basics are, allow turbocharger to get up to speed and temperature, while at idle, or very low rpm’s.
Also, allow turbocharger to spin down at idle preferably, before shutting down engine.
This allows for better lubricating and longer turbo life.
In my estimation, the autostart feature conflicts with these principles.
JettaRed (03-02-2024)
#38
#39
Not only bad for hot turbos a start stop is..............
Start Stop system if you guys watch MAHLE tech and Lake Speed Junior video, their R & D has seen more crankshaft damage from Start Stop system over long term.
Its a long video, I forgot which minute speak of START STOP, but very short discussion only on the start stop.
Crankshaft is a heavy component in fact the heaviest spinning component in an engine, and is floating on oil for its survival. Engine OFF means the crankshaft is touching or resting on metal bearing.
So overly frequent engine KILL-RUN/KILL-RUN in a start stop system is not doing the crankshaft any good.
The following 2 users liked this post by S-Prihadi:
CaliBenzDriver (03-02-2024),
juanmor40 (03-02-2024)
#40
Received 1,559 Likes
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 Sport (W212 @96K), 2015 ML350 (W166 @92K)
So far:
Start-stop disabled
Appropriate oil weight for climate/usage
Oil pump solenoid modification
Reasonable warm up/cool down routine
--> LONGER engine life, $$$ in savings long term
Start-stop disabled
#41
2016 E350 Sport
I hate to sound like a dunce, but I cannot get my Launch Creader Elite 2.0 Benz to
1) find the correct menu to enter from the Home screen
2) find the correct module to enter, then
3) find the auto start/stop menu.
4) What next, etc.
I thought I had found everything (previous post #31), but cannot navigate back to the same page.
Can someone please post a step-by-step instruction here or in PM to me? Thanks.
4) What next, etc.
#44
2016 E350 Sport
#45
Was it in the Engine Control (ME) module or the Instrument Cluster (IC) module?
#46
2016 E350 Sport
https://mbworld.org/forums/e-class-w...ii-reader.html
