2011 E350 stumbles bad at low Rpm
I had this happen once on my W211 after cleaning the throttle body & developed hard starts & stumbles that got progressively worse but no check engine. After throwing several parts at it to no avail, got it diagnosed and had to replace the throttle body
You can get the throttle body much cheaper online than at the dealer but it has to get programmed and in my case, they wouldn't do it if I sourced the TB elsewhere
Give all of the hoses connected to the intake a careful look over and make sure none are cracked or torn. Make sure the electrical connections going to things like the ignition coils and MAF are secure. Simple stuff, I know, but so many times it's something simple.
Stop beating your head against a wall and get a STAR/Xentry diagnostic - you'll be amazed at what a thorough and detailed examination it does. My local shop waives the diagnostic fee if I have them perform the repairs; maybe you could ask yours to do the same.
Post #1: starts with the MAF being out of question!
Assuming there are not CEL or related DTC to help speed up diagnostic:
This problem is when you can get $4k worth of repairs with nothing but an ECU reset + air filter ....
It's stumbling because of a seriously wrong mixture. It probably started with throttle lag and engine vibrations.
What maintenance items have been done vs. skipped over ?
>> Catch up with the basic maintenance items first then test for additional needs...
Can you see positive Fuel Trims indicating a lean engine with unmetered air:
- Camshaft rear covers
- PCV track
- Intake plenum seals ?
- Phasers?
I am not a fan of the bad "throttle body"... ECU scrutinize the plate feedback with top priority and triggers limp modes reliably.
> Can failed intake VVT phasers help produce that when they are rattling loose ?
.I'm going to follow this because I have the SAME exact problem goin on. I even changed the MAF sensor after the problem didn't resolve after cleaning it. Have you figured anything out. It is so incredibly frustrating!
The longterm fuel trim number... highly positive?
The fuel pressure during acceleration... falling down ??
New in-tank filter
