Sponsored by: CARiD
s212 air suspension - what should happen?
Old Feb 3, 2024 | 06:10 PM
mercerized's Avatar
2020 E450 4matic wagon
Greetings all 212 owner/operators,
Interesting event occurred February 2023. Began a 6 hour drive from home (SoCal 68°F) to the Sierras (5°F) and parked the car in the sub freezing temps for three days.
Contributors, nominally, what should happen to the height of the air bladders when I parked and left it cold soaking for three days?
a) decrease in height (i.e. pressure) i.a.w. PV=T
or
b) remain at same height
Old Feb 3, 2024 | 08:35 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
wet air freezes
Normal air contains moisture, compressed air contains condensate. ​​​​Same H2O that's known to expend below freezing.
That can play a number on rusted valves or air bags.
You know in Winter truckers are forced to use a special alcohol fluid to dry the air of their brake lines when crossing the Sierra Nevada. Frozen air lines are a real problem when water expends.
I wonder who knows how the Airmatic deals with condensate discharge ??
Old Feb 4, 2024 | 08:13 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
My last airmatic car was a '07 S550. it had a desiccant pack on the pump intake, I don't remember any condensate discharge?
Old Feb 6, 2024 | 12:24 PM
mercerized's Avatar
or
After the cold soak, the air suspension was nearly bottomed. Fired her up and it started to inflate to the typical ride height.
My theory is that the temperature of the slug of air during the six hour drive likely was somewhere around the ambient temps 40 to 50°F because most of the drive had an OAT about that. The last hour of the drive decreased to sub zero and that's when I parked for the next three days.
So, I think that answer is a) decrease in height because the slug of air decreased in pressure from the cold soaking.
Old Feb 6, 2024 | 01:11 PM
That does make sense, 1 psi drop for every ten degrees
Old Feb 7, 2024 | 05:21 PM
Arrie's Avatar
The pressure in the air springs does not change. It comes from the weight of the car. The volume of air goes down with lower temp so the car will lower down as the Airmatic does not run the compressor (smart) when car is not running.
Old Feb 9, 2024 | 05:58 PM
mercerized's Avatar
Indeed the volume decreases and the weight of the car remains the same force acting against the bladder surface area (like a piston compressing a slug of air).
However, if the car is nearly bottomed then it's highly probable that the air pressure in the bladder has decreased - all likelihood this situation is a combination of decreased pressure and volume.
