Sponsored by: CARiD
Finding Adaptive Brake Lights in Launch Menu
Old Mar 30, 2024 | 09:16 AM
JettaRed's Avatar
Veteran: Army
Originally Posted by ygmn
...I did email company I bought it from on Amazon; was not LAUNCH but Ediag
and they replied and suggested in email that ILS was a simple coding task if ya got the parts...
"Simple" is a relative term if you know what you are doing. And, yes, you need the hardware.
Old Mar 31, 2024 | 09:06 PM
shertex's Avatar
1991 300D, 2006 E320 CDI, 2014 E250 Bluetec
Update. So I made the coding change. But, even when I slam the brakes really hard (hard, but not enough to cause skidding), the brake lights don't flash. However, doing a little more research, the following conditions must be met in order for the lights to flash:
Vehicle speed greater than 50 km/hr
Deceleration 7.5m/s^2
BAS activated
ABS controls both front wheels.
I certainly didn't feel the ABS engaging (which I assume I would in the W212...unlike my W211).
Old Apr 1, 2024 | 09:15 AM
shertex's Avatar
So either I'm not braking hard enough to get the lights to flash. Or another possibility is that the country code needs to be changed from USA to ROW in order to "unlock" the feature.
Old Apr 1, 2024 | 09:22 AM
streborx's Avatar
Top Answer: 1
G550
I haven't explored or experimented with this coding on the Launch. Is there an Activation option in this brake light variant?
Old Apr 1, 2024 | 10:39 AM
JettaRed's Avatar
Veteran: Army
A lot of that is different in my 2015 W212..
ITem 35 had a different name but maybe similar under a different Item number nearby.
I Did not do it as I just did ECO one and figured 1 per day.
Here's simple!
Old Apr 11, 2024 | 08:52 PM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
Did mine
Old Apr 11, 2024 | 09:00 PM
  #32
JettaRed's Avatar
Veteran: Army
Kewl!
Old Apr 11, 2024 | 09:32 PM
  #33
shertex's Avatar
I changed the coding but in my "test run" wasn't able to get the lights to flash....guess I need to skid more!
Old Apr 12, 2024 | 04:45 AM
  #34
ygmn's Avatar
2015 E400 Sedan
Originally Posted by ml3504matic____
What coding did you do with the Launch to get it to work?
Old Apr 13, 2024 | 11:09 PM
  #35
S-Prihadi's Avatar
I am really enjoying this.........
You guys are like children with a new toy
Same excitement I had 2 years ago
Old Apr 25, 2024 | 08:07 PM
  #36
JettaRed's Avatar
Veteran: Army
Worth a bump!
Old Jul 4, 2024 | 12:11 PM
  #37
CLKx430's Avatar
14 E350 wagon
Any update
Old Jul 4, 2024 | 12:18 PM
  #38
Originally Posted by CLKx430
Any update
Will ask my friends, give me some time.
Old Jul 10, 2024 | 11:06 AM
  #39
o_Rage_o's Avatar
2015 E400 Coupe W207
Here I am.
Gateway: Must change vehicle variant to rest of world
In Front SAM: Warn_bli_enable --> "ja"
In Rear Sam: PRL_EB_Enabled_b --> "freigegeben"
If anyone is local in Toronto or wishes for remote work - I can also help code
