Sponsored by: CARiD
Finding Adaptive Brake Lights in Launch Menu
Old Mar 23, 2024 | 07:34 PM
shertex's Avatar
1991 300D, 2006 E320 CDI, 2014 E250 Bluetec
In Xentry, one finds adaptive brake lights as follows:
Under Rear SAM:
Blinkendes Bremslicht
Warnblinken nach Notbremsung
Both set to nicht zugelassen which should be set to zugelassen to enable.
But in Launch, I don't see those menu choices under variant coding. Can anyone with Launch help me find them?
Old Mar 24, 2024 | 06:42 AM
shertex's Avatar
Apparently Rear SAM menu is different in W212. I am told that the menu item is PRL_EB_Enabled_b. This value needs to be changed from nicht freigegeben to freigegeben.
Old Mar 24, 2024 | 08:32 AM
streborx's Avatar
Top Answer: 1
G550
Do all U.S. & CDN dealerships use Xentry written in German? Certainly could explain much about their competence.
Old Mar 24, 2024 | 04:31 PM
shertex's Avatar
I know it's under Function Release under Variant Coding. The problem is that many of the people who know this stuff cold are working with the German nomenclature whereas most everything in the Launch menu system is either English or some sort of abbreviation. Still looking to see what correlates to what.
Old Mar 24, 2024 | 05:05 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
hard core hacks
Dig in carefully like a surgeon!
The countless options all around these screens are overwhelming. It's nice is some ways for exposing so many fields but it sucks how screen keeps jumping back to the top without an index number to jump back to.
By the time you find a nice nugget it's even difficult to know where, how or what we got... DANKE!
What does the "adaptive brake light" do??
Old Mar 24, 2024 | 05:08 PM
JettaRed's Avatar
Veteran: Army
...What does the "adaptive brake light" do??
I think they flash like a strobe light while first being applied. It'll wake up the guy behind you.
Amazon Amazon
Pretty sure our cars would have conniptions if we tried to rewire the lights.
Blinkendes Bremslicht translates to flashing brake light.
Old Mar 24, 2024 | 06:49 PM
JettaRed's Avatar
Veteran: Army
I'm not finding anything remotely like "Blinkenfukinstoppenlampen" under Rear SAM on either of my cars. Could it just be the E-Class?
Old Mar 25, 2024 | 08:22 AM
shertex's Avatar
I found it.
Rear SAM
Variant Coding
Function Release
Item 35 Parking lamp_EB_Enabled_b
Change from Close to Open
Old Mar 25, 2024 | 09:07 AM
S-Prihadi's Avatar
It gets kinky and blink fast, the BRAKE light, not hazard
Old Mar 25, 2024 | 09:49 AM
streborx's Avatar
Top Answer: 1
G550
I found it.
Rear SAM
Variant Coding
Function Release
I like "Blinkenfukinstoppenlampen" much better -- is there a way to code that in? (lol)
Old Mar 25, 2024 | 11:50 AM
JettaRed's Avatar
Veteran: Army
I found it.
Rear SAM
Variant Coding
Function Release
Hmmm. Made the changes on my SL and no Blinkenfukinstoppenlampen. ☹️
Old Mar 25, 2024 | 11:51 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Yes but you'll need STAR/XENTRY C4 wireless usb obd2+ adapter with MBdiagnostic backwards compatible W212 read writeatibility to recode it in C++ with ComicSansSerif font.
Or a narrow stip of masking tape and a marker to make a new label to put on the screen.
Old Mar 25, 2024 | 04:36 PM
JettaRed's Avatar
Veteran: Army
After watching the video, I understand that the Blinkenfukinstoppenlampen only works in emergency stopping and not when normally applying the brakes (unless normal is always emergency stopping for you). Is that correct?
Old Mar 25, 2024 | 04:48 PM
shertex's Avatar
It's only hard braking above 31 mph.
Old Mar 25, 2024 | 04:58 PM
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
lol JK..........so not for 99% of MB owners then ...lol But prolly those who may need it are Italian and dont care about whats behind them anyways ( old movie reference ..CannonBall Run )
JK
Old Mar 26, 2024 | 09:24 AM
JettaRed's Avatar
Veteran: Army
Hmmm. Next time I'm in heavy traffic on the beltway, I'll have to test it and see if it works.
Old Mar 28, 2024 | 10:35 AM
strife's Avatar
560SL, 380SL, E350
It would be nice to know if this actually works. The only SAFE way to test this would be on a very lonely road with an observer FAR behind you and preferably on handsfree phone communicating. Maybe it could be done with a parked observer with binocs.
Generally, I do this manually by pumping the brakes irregularly when, for example, approaching a traffic jam ahead. That is, if I actually can SEE it. It is annoying that driving a car these days, it's hard to see over the #$%$% SUV's and trucks!
Old Mar 28, 2024 | 11:55 AM
streborx's Avatar
Top Answer: 1
G550
Just curious -- does anyone know if this mode kicks in when ABS takes over?
Old Mar 29, 2024 | 06:27 AM
Chamz333's Avatar
2011 w212, 2018 W166, 2024 v167
Under Rear SAM:
If you are trying to make the 3rd light flash fast then steady?
Old Mar 29, 2024 | 06:31 AM
Chamz333's Avatar
Flash- steady 3rd brake light
Old Mar 29, 2024 | 07:04 AM
JettaRed's Avatar
Veteran: Army
Have you gotten this to work on our cars?
Old Mar 29, 2024 | 07:36 AM
Chamz333's Avatar
Yes, worked perfectly on 2011 E350, 2018 GLE and 2024 GLE
Old Mar 29, 2024 | 07:41 PM
shertex's Avatar
Shouldn't need an observer to confirm. On mine at least, I can see the reflection of the center brake light in the rear window!
Old Mar 29, 2024 | 09:30 PM
wildta's Avatar
GLE 580
Does this same one work for your GLE?
Old Mar 30, 2024 | 05:57 AM
ygmn's Avatar
2015 E400 Sedan
I found it.
Rear SAM
Variant Coding
Function Release
A lot of that is different in my 2015 W212..
ITem 35 had a different name but maybe similar under a different Item number nearby.
I Did not do it as I just did ECO one and figured 1 per day.
I did email company I bought it from on Amazon; was not LAUNCH but Ediag
and they replied and suggested in email that ILS was a simple coding task if ya got the parts...
