Sponsored by: CARiD
RF ILS headlight intermittent fault
Old Apr 2, 2024 | 11:00 PM
Octan3's Avatar
2014 E550
Hi guys, random-intermittent rf headlight fault, E2N9 Rf headlight code b178711 actuator motor headlight range short to ground. from what I see this is simply the up-down motor like high beam low beam as per xentry tests. this morning it set just starting car up in drive way. I ran through xentry diag tests of full sweeps of the headlighs and it won't set the fault. Seems a bit coincidental to programming ILS+ last fall but I haven't had the car too long.
any thoughts or pointers?
Old Apr 3, 2024 | 02:15 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
ILS binding
The actuator motor is known to like binding and needs to be lubed with high temp lubricant.
I have not delt with that personally.
Old Apr 3, 2024 | 09:28 AM
Octan3's Avatar
2014 E550
I've been googling this and coming up dry on all fronts unfortunately. not finding anything mentioned about lubrication of something.
Old Feb 19, 2025 | 07:25 AM
yottabit's Avatar
2014 E350 4Matic
@Octan3 were you able to lubricate it? I'm experiencing the same fault
Old Jun 6, 2025 | 03:48 PM
nateo83's Avatar
Mercedes 2014 E350 Estate (S212)
Same issue... Any links to success to lubricate it, and any details on what to open, etc.?
