M271.860 EVO engine - GDI , carbon fouling at intake valves
93,000KM and of 2010 model year, C200.
This will be the same engine as W212 E200/E250 in Asia and Europe and C250 in USA.
From cylinder 4 to cylinder 1. Standard 2 intake valves per cylinder. 2 exhaust valves per cylinder.
Comparing to mine at 35,000KM approx. M276.820 3.0 Turbo
https://mbworld.org/forums/e-class-w...omparison.html
This car, its throttle modulation is not nice at all. It is a 5 speed tranny and now with so much carbon at intake valves its idling and traffic jam performance is NOT elegant.
Exhaust valves. I forgot the cylinder orientation...LOL
I don't like this engine. Albeit it is small, working on it is not too simple.
I tried blowing with my mouth the valve .. , I did not bring my hand pump to my indie and not wanting to use compressor powerful air.... this PARTIAL LOAD valve , it can't open.
I was too lazy to blow the other way round, but I am sure I am correct for its airflow direction, it is a check valve after all....engine block to intake manifold.
When new valve arrive, I shall update. MB Indonesia been lame, commit 30 days and now 45 days still parts have not arrived.
I send my camera into that funnel shaped CYCLONE Separator cavity at engine block, its is clean actually.
This engine PCV is faulty, it does not have proper vacuum reading at idling or 3,000 RPM measured at oil dipstick...very very weak vacuum.
The plastic cylinder head cover is the FULL LOAD PCV system.
I tried using compressed air, it does have flow but honestly I do not know if the flow is good enough.
Inside it there are some sort of "valves" too. A W204 member have tear down his unit..cut it a part. Its like Audi/VW PCV on its plastic cylinder head.
So far so good.
However, I am still not happy that the engine vacuum reading which I sense at engine oil dipstick seems to be too low, albeit negative value.
Too bad no such data exist for this M271 engine, or even for my M276.820 engine.
But for my M276.820 engine the vacuum value is comparable to BMW N55 engine, also a 3 liter in line 6 cylinders turbocharged.
