Sponsored by: CARiD
Mr
Old Jan 27, 2025 | 01:40 PM
hasan ayoush's Avatar
Mr
Hello MB people,
I have E200 2011 Bluetec, the car was running smoothly, until i went for a garage to change the engine oil .
the tech said that there was an oil leak from the seal convertor so we did seal convertor replacement and rear seal , after that the car start doing over rev on low speeds between 1-2/2-3 gear , and later some jerks comes up to the surface.
i was advised to do a Tranny fluid and convertor oil change but no help, it's getting worse.
yesterday, I changed the transmission but the problem still there.
please note that there is not a single fault code in ECU OR TCU .
I still have until Friday warranty for the gear. Maybe i can have an advise from someone who faced this issue.
i am in Dubai
Old Jan 27, 2025 | 02:15 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Whats the issue that need attention?
Old Jan 27, 2025 | 02:41 PM
i believe i my issue is clear
Old Jan 27, 2025 | 04:09 PM
ChuangTzu's Avatar
19 GLA45, 86 560SL, former: 14 E550 4Matic, 09 E350 4Matic, 83 240D manual, 78 450SLC, 81 500SLC
You have a brand new transmission and the transmission appears to be slipping. But you have no fault codes...
It seems like whoever installed the new transmission did not do it correctly.
