Sponsored by: CARiD
Battery size
Old Jul 5, 2024 | 09:25 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Battery size
Was cleaning the engine bay of the new to me 2010 C207 and removed the air box cover and saw a tiny H6 AGM battery. It is too small that it wont clamp down. I need to replace this thing before it decides to jump and destroys the box and other stuff. Upon looking at the online stores it gives H6, H7 and H8 sizes. So either ot is a H7 or H8 but wont risk buying the wrong one so help out if you know the original size.
Old Jul 5, 2024 | 11:04 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Coupe H7 sedan H8 from what I have read. Pretty easy search.
https://mbworld.org/forums/e-class-c...y-fitment.html
Old Jul 6, 2024 | 01:47 AM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
diesels tend to use the largest battery sizes
Old Jul 6, 2024 | 03:18 AM
Thanks for the link. H7 it is then.
Old Jul 6, 2024 | 03:59 AM
all of those H batteries (there's an H9 too) should be held down by clamps on a flange on the bottom of the 'front' and 'back' side of the battery. all of them are the same ~ 6 7/8" deep and ~ 7.5" high (really, 175mm x 190mm), the H6 is about 9.4" wide, the H7 is 11" wide, the H8 is almost 14" wide, and the H9 is about 15.6" wide. You should always be able to physically fit a smaller H size into a larger H tray.
Old Jul 6, 2024 | 11:04 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Generally yes, but for US, it is the list of gadgets, what require bigger battery capacity. Those power seats, who operate without engine starting, safety lights that stay on after you lock the vehicle take some extra power.
But European version often have H6 batteries for V6 diesels, when in US everything goes H8.
When you are in cold climates, you can use the extra capacity for seat heaters, but in warm climates, you are carrying extra dead weight.
You can still buy flooded H6 for about $80, when good looking one at Costco is about $110.
Old Jul 7, 2024 | 06:16 AM
ygmn's Avatar
2015 E400 Sedan
where are you buying batteries for $80?
Local costco here has them for $170
Lowest I find for decent name brand is $160.
Old Jul 7, 2024 | 06:19 AM
These cars are supposed to have AGM batts.
Old Jul 7, 2024 | 07:32 AM
JettaRed's Avatar
Veteran: Army
Concur. The importance of getting the right and proper battery cannot be overstated since modern Mercedes cars are so temperamental when it comes to electrical sources. The wrong battery will cause all sorts of phantom problems. It is generally recommended to get genuine Mercedes batteries from the dealer. (However, I haven't but paid enough for the ones I got that the dealer would have probably been cheaper.) Definitely need to stick to AGM batteries. AGM and traditional (Flooded/Wet Cell) batteries have different charging profiles. Putting a flooded battery in place of an AGM battery may cause over-charging.
Flooded Batteries vs. AGM Batteries: Understanding the Differences - Power Sonic (power-sonic.com)
Old Jul 7, 2024 | 01:06 PM
FWIW, our E350 has done just fine with a East Penn Deka "Intimidator" AGM 9A49 (Group 49 aka H8).
Old Jul 7, 2024 | 03:22 PM
JettaRed's Avatar
Veteran: Army
And this is what I currently have in my SL400. I replaced both my batteries when I would have random blind spot failures. Not sure if both needed to be replaced, but I did anyway. I have the old batteries on CTEK trickle chargers.
