Sponsored by: CARiD
super-intermittent starting issue
Old Aug 7, 2024 | 06:47 AM
djneils's Avatar
e class
I have an E350d 2010 and every so often I will start the car only for the engine fire up and then to instantly cut out and die.
It can start fine for weeks potentially before doing this and it always starts fine if I take the key out and try again.
I had the codes read but nothing relevant is logged.
Any ideas?
Old Aug 7, 2024 | 06:25 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Any ideas?
Randomness is genuinely puzzling.
It sounds electrical more than fuel related.
Good thing it does not quit while driving.
This may be related to solderless EIS keyswitch...
Get yourself a scanner ready for next time this happens.
You want to avoid clueless guessing as much as practical. Everything is possible.
Old Aug 8, 2024 | 05:06 AM
djneils's Avatar
e class
I did get it scanned and there were no related fault codes logged
Old Aug 8, 2024 | 02:00 PM
suggestions....
Without a usable scanner for troubleshooting, it's harder to call the right part.
Lately a lot of chassis engines disfunction without related fault codes. . .
There's something you can do that will positively help and not cost you a small fortune: Driver-side SAM power relay maintenance.
Use a schematic to list main circuits to the following Modules:
  1. ECU,
  2. Fuel pump,
  3. CGW,
  4. ESP
Only buy from trusted parts source.
