Sponsored by: CARiD
No audio
Old Sep 12, 2024 | 05:02 AM
1bad550's Avatar
No audio
Good morning fellas, about a week or two back I was cruising on the highway and suddenly the music cut out in an instant, everything else works as it should in the screen menu. When I checked the cars codes through the engineering menu this is what I got, is this simply a case of replacing the Bluetooth Phone Control module to restore sound?
Old Sep 12, 2024 | 08:18 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
not obvious
there are couple known audio issues but there are couple different options in use.
So it's not trivial to gues right!
  • the head unit
  • the main amp
  • AUX interface
  • and MOST fiber ring
  • none of which are cheap or simple to replace!
Use a good MB scanner to pull faults.
Old Sep 12, 2024 | 10:49 PM
1bad550's Avatar
  • the head unit
  • the main amp
  • AUX interface
thank you for the info, I will scan it soon to get the mb specific codes, what’s weird to me is this morning when I started the car up, the audio started blasting for about ten seconds then cut back out. Thought I lucked out but I guess not.
Old Sep 15, 2024 | 01:56 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
i'll hazard a guess that a connector is loose somewhere, maybe the MOST (fiber optic) output from the head unit to the amplification
Old Sep 15, 2024 | 04:33 PM
Works fine, for 10secs!
that's good news! This means your amplifier is not toasted.
I bet on it's a logical issue...
something on CAN-B ?
Media interface module ?
head unit itself ?
Old Sep 15, 2024 | 05:17 PM
1bad550's Avatar
head unit itself ?
for the head unit
Does the internal control unit reset mean anything? Both the head unit and media interface module have errors
