Is there an Internal adjustment to the Handbrake?? Handle??
2013 E350 Facelift (Japan Import) 2007 E350 Elegance Wagon, 2014 E350 Wagon facelift model Jap Model
Hi Guys,
My 2014 E 350 wagon, facelift, has this really annoying handbrake issue in that to release the handbrake I have pull, pull, pull, pull the handle for it to release!!
Is there some kind of internal adjustment for this as the only YouTube vids I can find talk about rear shoe adjustment and I did those when I replaced the pads and skimmed the rear rotors.
Cheers!
Cheers!
MY'14 W212 M276 3.5NA @60kMi
this is a standard issue where light grease evaporates and turns into glue. Some ppl spray lubricant at it... the best way is to clean the cheap grease with brake cleaner and replace it with good silicone lubricant
The following 2 users liked this post by CaliBenzDriver:
Aussie_E350_Wag (09-23-2024),
pierrejoliat (09-24-2024)
Where do I spray the lubricant please?
Cheers!
on the mechanism of the emergency/parking pedal. It's one big coil spring... when you push down it all get stuck on itself tight... perfectly engineered for timely service.
1- Clean old sticky glue remainders
2- Lube coil spring
(don't inhale toxic benzene propellant!!)
2- Lube coil spring
Aussie_E350_Wag (09-24-2024),
2016 E350 4Matic wagon, 2019 Ford Expedition 4x4
my wife's e350 4matic quote often warns about the parking brake being set when its not. pulling the release handle clears it but I'm quite positive I hadn't touched the pedal before this.
here is one of the several threads discussing this known topic, which I also went through myself.
https://mbworld.org/forums/e-class-w...ml#post7034734
The following 5 users liked this post by JCM_MB:
BenzV12 (09-24-2024),
CaliBenzDriver (09-23-2024),
Jaybird123 (09-23-2024),
The following 3 users liked this post by Aussie_E350_Wag:
