Question About Steering Wheel Compatibility
From the outside, both steering wheels look identical, but I’m unsure if all the functions (like Active Lane assist) will work as they should since the part numbers are different.
Can someone help clarify the differences and whether the replacement will be fully compatible before I make the purchase?
This is the one I intend to buy.
W212
One thing I've noticed is that your wheel seems to be brown while the picture of the replacement one seems to be black.
If something does not work, consider your options. I have taken off many wheels (well, four or five) for clock spring replacement. This aint rocket science. It is about a three out of ten for difficulty. Supposedly you are supposed to disconnect the battery incase the airbag...blah blah blah. I never have.
Reinstall in opposite order. It is VERY simple. While you are in there you may want to put in a new clock spring for good measure. That is the reason I have been into more than one Mercedes steering wheel.
W212
So if you have the lane keep option you need steering wheel with a space for that little shaker motor.
I replaced the steering wheel and transferred all the wiring from the old to the new one. I also installed Active Lane Assist as there was a space in the new one, and all functions are working well.
However, I’ve noticed a small gap between the airbag and the steering wheel, and the horn has become harder to press. It still works but requires extra force.
Any suggestion to fix this gap ( even though it is not noticeable, I want to have a perfect look )
