Sponsored by: CARiD
Misfire Cylinder #1, brand new coils and spark plugs. Please help!
Old Oct 13, 2024 | 07:12 PM
  #51
JettaRed's Avatar
Veteran: Army
Originally Posted by GOPHIMBO
And just today, my garage door spring broke.. Problems comes in 3s.. like they say. LOL
Easy fix. About $20 a pair from Home Depot. There should be some paint on the original ones that mark the strength. Get the same.
Old Oct 13, 2024 | 08:43 PM
  #52
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by tesna
Mine has oil squirting from the small port #2, the vacuum still somewhat worked (the intake manifold flap still actuates). Can I add the check valve inline if mine squirting oils?
​​​​@S-Prihadi is this small check valve available in our local market 😅
Okay, we can do better than stock...
we can add a protection to blow pressure out of vacuum line.
It is normally desirable for pp to have oil inside but it should not pump it out into the vacuum lines
Right now you vaccum pp is pumping oil out... we want to prevent that to preserve functionality.
> How To Vent Pressure...
-- Add a "T" branch to existing line with a second check-valve plummed to vent pressure out and hold vacuum in.
-- After that "blow out" branch, add you new in-line check valve to hold vacuum for existing accessories.
These two check-valves need to best be silicone to wistand 250°F hot oil duty.
FYI: when I got my cylinders to seal with better oiling, I got surprised by:
lower CC pressure improving my brake response!!!
Old Oct 15, 2024 | 05:50 AM
  #53
S-Prihadi's Avatar
There is a difference actually from a regular check valve to a membrane type stop/check valve.
Check valve usually has spring and some sort of ball as the valve. It takes more effort to un-seat the ball/valve, they call it the cracking pressure.
Membrane like found on the vacuum pump is the lightest easiest to deflect/move.
If you guys do snorkeling and have the snorkel with the membrane type water stop valve, that is very similar with the one used on the vacuum pump.
So if one is to get a check valve, get one with a membrane.
Old Oct 15, 2024 | 09:45 AM
  #54
JettaRed's Avatar
Veteran: Army
Ha! The snorkel I had as a kid was S-shaped with a cage and ball on the top end that would keep water out when diving under the water.
(I can't even find a picture of one it is so old now.)
Old Oct 15, 2024 | 09:57 AM
  #55
S-Prihadi's Avatar
Here u go......
Old Oct 15, 2024 | 10:03 AM
  #56
JettaRed's Avatar
Veteran: Army
Originally Posted by S-Prihadi
Here u go......
Old Nov 2, 2024 | 06:38 PM
  #57
GOPHIMBO's Avatar
2011 E350
This confirms it. one of the levers are broken.
