Sponsored by: CARiD
Loud noise on start up
Old Dec 15, 2024 | 10:18 PM
Tom pepicelli's Avatar
R320, S211 wagon
Hi all,
I've got an e400 that has this loud noise (video attached below) when starting the car warm/cold.
What do you guys think could be causing the noise? Timing chain?
Car has 70,000km on it and its been maintained well.
File Type: mov
Old Dec 16, 2024 | 12:18 AM
S-Prihadi's Avatar
That is very likely one or two bad VVT ( camshaft phaser/ADJUSTER ) . 70,000KM is very low mileage to have this.
My friend's M271.8 had almost as loud VVT issue as yours, but yours to date is the loudest one I have heard.
E400 too. But DO NOT follow his VVT loosening and tightening procedure !!!
M278, bigger brother to M276.8 of yours ( OURS )
M276.9 3.5 NA , cousin of M276.8 3.0 Turbo
Old Dec 16, 2024 | 02:00 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
from $500 to $2500
You can start replacing only the secondary chain tensioners ($100Ea), simple job.
Then if that's not enough, later replace 2x intake VVT's with related job : PCV + HPFP.
So this goes from a simple $500 job to easily $2500+
This issue is caused & worsened by limited oiling pressure.
Provide better oiling than stock conditions (0w40 every 15Km).
The secondary chains and guides are good to keep.
Old Dec 20, 2024 | 01:49 AM
R320, S211 wagon
Thanks guys for the info, much appreciated. Will start investigating.
