Sponsored by: CARiD
WIS Front Wheel Bearing 4matic
Old Dec 21, 2024 | 05:24 PM
mercerized's Avatar
2020 E450 4matic wagon
Hello forum members,
Preparing to replace my wheel bearings and the job requires full access to the knuckle.
I'd like to know what the torque up values are for the control arms nuts, drive shaft bolt, etc.
Would any of you kind people be able to upload the instruction?
Much appreciated. RGDS, Roger
Old Dec 23, 2024 | 12:18 AM
TimC300's Avatar
Here you go, look it up: https://charm.li/Mercedes%20Benz/2013/
Old Dec 23, 2024 | 12:48 AM
TimC300's Avatar
I tried looking at the E350 instructions and for some reason they dont have much. Ive been looking thru the 2010 C300 for my car and they have plenty of instructions. You may have to look around.
I know the specs are similar if not the same with the W204. I'll post what I have copied. Axle bolt, sway bar links and the tie rod.
Old Dec 23, 2024 | 01:23 AM
mercerized's Avatar
Appreciate it.
My copy of the WIS and EPC is on my laptop that my son took to for engineering school. Looking around for a laptop with Xentry and a passthru.
Old Dec 23, 2024 | 10:35 AM
TimC300's Avatar
Found the 212 torque strut and cross strut torque specs. Finally found them looking thru the 2010 E550 manual. https://charm.li/Mercedes%20Benz/201...d%20Diagnosis/
I noticed under the steering knuckle instructions it says 50nm + 60 degrees, yet in the other sheet I have it says 50nm + 90 degrees. I would go with the 90 degrees. Here is the AR33.25-P-0400EWX Remove/install steering knuckle: https://charm.li/Mercedes%20Benz/201...0and%20Repair/
Old Dec 23, 2024 | 02:08 PM
mercerized's Avatar
Check this out..."Airmatic front strut"
https://mbworld.org/forums/e-class-w...ml#post7481220
Funny how the forum has a lot the content.
