End of year tools
Sharing what I got this year..........
Its often the case end of year is the time I bother friends who has kids/home in USA, to keep my stuff I shipped to them and their Daddy ( my friend ) bring it back to Indonesia because
they visited the kids in USA, or the kids goes back to Indonesia for year end holiday.
Usually it is small light weight stuff and not worth paying Amazon to ship to me direct Jakarta-Indonesia as the product price is so cheap, the courier cost to Indonesia
is then 4x the product price
If very heavy stuff like my 5000 EXT Quick Jack at 250 lbs or 113KG, me will ship UPS Air Freight Consolidated which is cheaper than speedy UPS or speedy Fed-EX at approx US$4 ( before Covid )
per kg but they want minimum weight like 150 lbs if I recall and it will be 2+ weeks and not the usual speedy 3-4 days USA to Jakarta or Singapore.
If I live in USA, I will go broke from buying tools.....
, I love them and so easy to buy in USA.FYI, my government has banned AliExpress.com from shipping direct to Indonesia.
I can understand why my government is doing this to protect small businesses in my country.
I have to say after near 100 purchases at AliExpress, NONE of them sellers when shipping out to Indonesia will declare actual price of goods for Custom,
they will always under declare by crazy cheap. Aliexpress also uses Singapore as a cheaper transit price to reduce CIF price.
This means the source of goods in then logged as Singapore and not China.
I can still use BangGood which is honest for Custom declaration on price, but BangGood does not sell much stuff, more so mechanical stuff.
More for electronics instrumentation , DMM, power supply etc etc....those kind.
This year I got these tools :
01. https://www.ebay.com/itm/115031991586 just arrived in Jakarta 2 days ago. U$134 landed and tax paid. So its double the original FOB price, almost.
Carbon pile battery tester, 500 amps.
02. https://www.pelicanparts.com/More_In...L-007776SCH01B
Mercedes Rear Spring compressor tool, supposedly does not have compatibility data for W212, but I took the risk and get it anyway because I am sure it will work.
03. Coin shaped slotted screw driver....damn, I never knew such screw driver exist.
https://www.amazon.com/PB-Swiss-PB-8.../dp/B00TPBTEP2
The beauty of USA Amazon.......
Regular scredriver , does not have the width and the "polite" edges for on car under body jack pad coin shaped slotted screw.... I damaged the screw slot on one new Jack Pad already...duggghh !!!!
04. N73 EIS/EZS removal tool. Again here W212 is not mentioned, but it is so cheap... so what.
https://www.amazon.com/dp/B0BCW24SL3...fed_asin_title
05. Heat shrink tube with glue. This is good stuff, I already bought some in 2023.
Now I buy more:
If 1/8" size https://www.amazon.com/dp/B01F2LFSHG...fed_asin_title
If 1/4" size https://www.amazon.com/dp/B0861RFS34...sin_title&th=1
If 1/2 size https://www.amazon.com/dp/B0861RFS34...sin_title&th=1
I can't get locally heat shrink this thick and has glue as waterproof sealer at small diameter. The one available is bigger diameter for
big 230/400V electrical cable of at least 5/8" OD.
06. https://www.amazon.com/dp/B0BDG6V2L5...fed_asin_title
This is so cute.... and will come handy.
07. I hope this one fits my turbo charger intake pipe OD
https://www.amazon.com/dp/B0D12BLJZZ...fed_asin_title
08. So cheap in USA and a Class 3, dang, at the best I can get locally is Class 2 and at 200% the price.
https://www.amazon.com/dp/B09HP5572Z...fed_asin_title
This is not a tool per-se, its for me when and if my car breakdown at night...... https://mbworld.org/forums/e-class-w...tive-vest.html
Awesome 3M genuine cloth/fabric type reflector
Schwaben is not a German brand.
https://iatn.net/reviews/schwaben-to...hwaben%20Tools.
This brand is owned by ECS Tuning. https://www.ecstuning.com/News/Schwa..._10PercentOff/
So, 99% this is China made and not European/German made at such price (more so with mark-up by ECS ).
I am counting on decent reliability/strenght for DIY use, which is say 10 uses per year maximum.
You can get cheaper one at Amazon, but since China made goods has so many small home type factory making them, some can be really bad and some can be decent.
Metal parts holding 500KG / 1,100 lbs of compression is indeed scary if not well made and this is a single screw type spring compressor tool, unlike common 2 units claw type spring compressors.
https://www.amazon.com/mercedes-spri...ing+compressor
Thus I rather pay more for Schwaben because the handler in USA is a US company ( ECS Tuning ) thus legally they know the risk of this spring compressor will break and hurt people.
To me rear spring compressing and then removing it out of the spring arm while being compressed is VERY DANGEROUS.
Front spring is much safer, I use 3 of single rod spring compressor tool and when compressing the spring we can aim the top mount away from us, as the mcphearson strut
is already out of the car.
I would probably use this Schwaben spring compressor only for installation and not total 100% removal.
What I mean by total 100% removal is WHEN we are not using jack* at spring arm ( load shared by spring arm to jack ) and not finally removing spring arm bolt at subframe.
If one has done rear spring arm of W212, one would know what I mean .
END
I bought the Taiwanese version of that spring compressor about 20 years ago. Since then I have used it on a W123 (works pretty well) and a W211. On the W211, it just barely works. I think I had to compress and uncompress the spring a few times during each operation which was pretty sketchy. The end that has the 1/2" drive was sticking out and interfering with parts of the car. After repositioning the tool, the opposite end was pressing on something else. I got it to work, but it was a huge PITA. Hopefully it works better on a W212 because I will be trying it there next. I wish I remembered the details but I was too frustrated to make any documentation at the time and was quick to forget the experience. I was even contemplating grinding an unnecessary part of the tool down a tiny bit for a little more clearance.
Edit: By the way, I paid $250 for the Taiwanese tool 20 years ago. That's about $500 now. The Klann was about $500 then, which would be $1000 now. I just looked it up and it does sell for about $1000...
I also just noticed that the Klann comes in a long and a short version...
Can this one be used for REAR spring ?
I think this is for front spring, its design is to be used at outside of the spring and not inside the spring, right ?
https://www.samstagsales.com/klann_spring.htmBut how come none stated suitable for W212 ?
Even using it for the fronts would scare the crap out of me.
Be scared if ya want but it worked perfectly well. Much better than the crappy one I got at NAPA which was actually scary and I gave up on. Like I said after removing the plastic inserts it worked perfectly fine and have scene it working great on various other videos as well. If I remember correctly it was also linked on this forum possibly by one of the "gurus" here.
YES, but me in Bali now using laptop only, my PC where WIS and EPC is parked at, is at home in Jakarta.
I will pass it to you after 7th Jan 2025 yah.
EDIT EDIT============
Go to post #8 below, the P/N of the W212 rear spring compressor is there
https://mbworld.org/forums/e-class-w...ml#post9067699
Granted those are China made Vevor brand , even locally sourced 8.8 steel threadred stud/rod of M10 after a few uses it will need to be retired.
Even the NUT get its thread stripped
Quint already pointed out the probable reason
This threaded rod/stud is what I fear most if not of a superior or suitable material and used as coil spring compressor.
The dirty spring compressor is USA made, 30ish over years old I borrow from my cousin workshop.
The shiny new ones are surely China made.
I now uses 3 spring compressors for front coil spring works. All 3 china made. I don't have the photo with me at the moment.
3 units can allow good even compression, as such sitting this awkward angled spring becomes easier, thus not only safer sharing 1/3 load each.
Photo of 3 units in use , USA made one as 3rd unit. The dirty one.
Rear coil springs compressor being a single rod/stud design is kinda scarry, I think they use M14 size stud/rod.
Typical W212 is 500kg / 1,100 LBS spring pressure each as good approximation, simply to keep ride height.
Thus for rear, when one does spring removal like below's video, albeit not W212 but much older MB, I think that kind of fully compressed spring is easy 650kg / 1,430 lbs worth, if not more.
Don't follow this guy method of using impact tool on spring compressor, its dangerous.
The 2nd image above is my number 1 fear. I would not dare to use the Schwaben to that extend, a 100% coil spring removal using it , is what I call the term.
I will not want my hand holding my rear spring fully compressed like above, I will only use the spring compressor as tension reduction tool for ease of
removal, but will use hydraulic jack and spring arm assist as final safety measure. Thus the spring compressor tool and the spring will stay inside the spring arm
cavity at all times during compression of the spring. I can release slowly the spring compressor tool with hydraulic jack assist, when spring arm bolt at subframe
already removed.
My typical dual jacks method to prevent screw up from powerful rear spring becoming missile.
The right side screw type jack is rated at 500kg only for motorbike. Hence I use extra hydraulic jack.
I also do not want to use rear spring compressor with locking design of top spring plate like below's video, its more risky to use.
17th second is the spring "explosion". Short clip version.
Screen capture below is from the full clip of 20 minutes.
Schwaben copied MB official tool design, which is a better design.
It seems the stud/rod thread is at least M16 ( 16mm / 5/8"), if not M18. Me has no caliper at the moment in Bali.
However if I want accuracy for spring end stop to be at its maximum end stop, I am hoping this new spring compressor will help.
I have yet to see anyone specifically mentioning about spring end, hitting its maximum end stop after re-installation of the coil spring.
To remove the rear springs in my W204 I just stuck a floor jack under the inside under the spring control arm, removed the bolt then lowered the arm down and the spring pulled right out. No compressor needed. I felt I was perfectly safe the whole time. just go slow.
When I had a front spring break I just bought a complete strut instead. Just remove the old strut and install the new and call it a day. But if i had to replace the front spring i would probably buy a compressor like this:
It could also be because the lower shim was not smooth like new anymore , and the self-parking of the rear coil spring did not happen fast.
