Sponsored by: CARiD
Holy crap 90% humidity madness
Old Jun 16, 2025 | 06:39 AM
S-Prihadi's Avatar
UPDATE
I been discipline in maintaining my car interior humidity level ever since I made this post.
If I do not open my car door, I can get away with 4 days of humidity reaching 65% ish and then I DEHUMI it again.
Everytime I done the dehumifying, by the time I am done closing the door and removing the DEMU unit yada yada, the humidity from the 43% lowest when HUMI unit running,
will settle to 50%.
Everyday it will climb 2-3% there about.
If I use the car, even with HVAC making the interior air dry, the amount of door opening event is plenty enough, I can DEHUMI the car and get 300ish cc of water.
If I do not use the car for the 4 days since I last DEHUMI it, I get 200ish cc of water only by next DEHUMI session.
if I DEHUMI it again within 2 days, I won't get more than 100ish cc of water.
Something I noticed as remarkable.
I never paid attention to humidity as I was born and lived in the tropics all my life and I was diving al lot, so high humidity is my daily bread but low humidity is a slow progression
whenever I turned ON the HVAC in my room or on the yacht. Thus I never got the chance to feel the same 31C but one at 85% RH and my car interior at 50ish % RH withing 1 second.
These past few weeks been very hot as usual, and I was messing around and was mild sweating.
Everytime I open my car door and feel the car interior air at the same 31C as outside, but 30% less humidity, DAMN, I can feel the air seems like 2-3 Celsius ( 4-5F ) cooler !!! So awesome.
I read about this easier evaporative cooling in drier air, but I never had the chance to feel it apple to apple at 31C. and I can switch in and out within seconds.
Thats all the report.....
Old Jun 16, 2025 | 09:05 AM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
rom Summit Racing. Found on web, I have no interest in this. $579
CarCapsule Indoor Vehicle Enclosures CC18F
5 out of 5 stars ( 3 )
Part Number: CCE-CC18
Overview
Brand:
CarCapsule USA
Manufacturer's Part Number:
CC18F
Part Type:
Vehicle Enclosures
Product Line:
Summit Racing Part Number:
CCE-CC18F
UPC:
857088003412
Vehicle Cover Material:
PVC
Vehicle Cover Color:
Clear
Overall Width (in.):
78.00 in.
Overall Length (in.):
216.00 in.
Overall Height (in.):
68.00 in.
Fan Included:
Yes
Quantity:
Sold individually.CarCapsule Indoor Vehicle Enclosures
Give your treasured vehicle the protection it deserves from dust, dirt, dings, corrosion, mildew, musty odors, pests, and insects with a CarCapsule indoor vehicle enclosure. They're great for maintaining that showroom shine all year-round! The CarCapsule—or bubble, as it's also known—provides an easy-to-use, debris-free enclosure for cars or trucks. And, they're easy as 1-2-3 to set up in less than 15 minutes!
Once your car is positioned on the base mat, attach the fan, zip it up, and plug it in. No assembly is required. The washable charcoal filter and high-cfm fan will keep contaminants out, maintaining a pristine environment inside! Order the size needed for your particular vehicle.
Additional features of CarCapsule indoor vehicle enclosures:
* Durable, clear PVC top cover
* Base mat is mildew, abrasion and flame-resistant
* Heavy-duty base mat is impervious to oil, gas, and antifreeze
* Rust-free: 100 percent nylon self-healing coil zippers
* No metal parts inside, no metal frame, and no bare metal
* Fan: 190 cfm at 4200 rpm, dual ball bearing for continuously filtered airflow
* 12 V, 1.5 amp power transformer
* Includes fan, power supply, and washable charcoal filter
* CarCapsule comes in 12, 14, 16, 18, 20, and 22 ft. lengths
Old Jun 16, 2025 | 10:43 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Capsules are a great solution to control environmental exposure to a car.
S-Prihadi, are you aware of Las Vegas? It has one of the highest average temperatures of any US city, and regularly sees 40C in summer months(Jul-Sep) and some excursions to 50C. Our way of coping with the heat is an attempt at humor from an old saying by residents and tourists. “It’s hot, but it’s a dry heat”. There is a lot of truth to low humidity making higher temperatures more bearable, and high humidity making lower temperatures more bearable. Of course high heat and high humidity quickly becomes unbearable, unless you are acclimated.
Old Jun 16, 2025 | 09:37 PM
S-Prihadi's Avatar
I know Vegas is hot, but crazy dry...amazing.
Never beeen there though.
I often visited humid Florida area due to yachts related activity, but now I hate travelling, when above 7 hours flight.
Old Sep 24, 2025 | 10:33 AM
S-Prihadi's Avatar
Sharing......
I got Temp and Humidty logger, for data logging sake.
From left 0, or zero hour to #1, that is the logger placed in the car before I use dehumi unit.
#1 and A is dehumi unit in action for 8 hours.
#2 is the humidity stabilizing or reaching its equiblirium inside the car. All fabrics dan carpet do hold moisture, can't escape that fact.
I kept dehumi in the car for some hours, never drain the collected water.
I open the door and get spike up at #2 tip and run again the demuhi for 2 hours till #3 where best RH is 32%. Can't do better. It is the dehumi unit limit.
A , B and C is the car interior getting warmed up by dehumi hot exhaust air cooling its condenser. A being highest because of 8 hours run.
#4 to #5 is another dehiumi run of 2 hours and I removed the dehumi unit and collected 400cc of pure distilled water.
Highest record I can collect water is 450cc.
Lowest I ever collected if 8 hours run and car was dehudified say 3 days ago, its about 250cc.
#6 is the car interior RH slowly rising, #7 is me opening the door and close it again, the same as #8 and #9.
#10 is me keeping door open for long time and finally removing the temp & RH logger, to download its data.
The logging is 1 data point per 10 seconds.
This confirmed the previous measurement by eye balling the humidity and temp small sensor I placed inside the car.
One time dehumifying the car for 4 hours and immediately removing the unit ( because it has water collection bowl ), should be able to keep the car RH under 60% for 4 days if doors never opened.
This new logger supposedly is well calibrated. Its reading on RH is between my smaller and bigger sensors. It can hold max 100,000 data points or good to 10 days approx at
10 second per 1 data point.
END
Old Sep 24, 2025 | 03:26 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
S. Prihadi,
You have a dashed line on your graph.
It appears to represent a mid 30’s scalar.
Is that an optimum measure for heat and humidity?
If not, what is the static heat and humidity that would be ideal?
Old Sep 24, 2025 | 11:03 PM
  #32
S-Prihadi's Avatar
Originally Posted by MB2timer
S. Prihadi,
No.
Those lines seems to be how the apps designer wanted
The apps is very clunkly.
