Sponsored by: CARiD
Aftermarket Voltmeter Not Working
Old Feb 23, 2025 | 06:57 PM
Pantomime's Avatar
2016 E350 Sport
I never use car’s cigarette lighter so took it out and replaced it with a voltmeter which can also charge my phone. When I removed cigarette lighter, it was attached to 3 wires, a red, a brown and a thin grey wire. Voltmeter had 2 prongs, a positive and a negative. So, I assumed the red wire from car would plug into the red positive and the brown would go with the negative prong. I assumed the thin grey wire was for lighting the cigarette lighter, so I left it alone.
After I buttoned up everything, voltmeter didn’t power up, and thankfully no fuses got blown, that I could tell. I’m not sure why it’s not working, but is it possible that brown wire is positive and red is negative?.i could remove center console and check polarity but it was a pain in the azz, which I’d rather not do.
Old Feb 23, 2025 | 08:23 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
no outlet pwr
yes, the solid brown is used as GND.
Use a DVM to figure whats happening with your chassis.
Its a safe bet the related fuse got zapped.
Old Feb 23, 2025 | 08:29 PM
Pantomime's Avatar
2016 E350 Sport
That cigarette lighter fuse is located in the trunk #71, will have to check it by day.
Old Feb 23, 2025 | 11:10 PM
I really like your MOD to read DC Voltage and supply smart phone charge.
What module is that your using ???
Ok found it on eBay $10 to 12Ea... nice!
Note this voltage source is a bit lower than what the main battery gets... not a problem.
Old Feb 24, 2025 | 08:27 AM
streborx's Avatar
Top Answer: 1
G550
Why did you not simply use a voltmeter that plugs in the 12V socket?
Old Feb 24, 2025 | 11:32 AM
Pantomime's Avatar
2016 E350 Sport
I could have done that, but I like permanent fixtures
Old Mar 2, 2025 | 08:10 PM
Pantomime's Avatar
2016 E350 Sport
Replacing cigarette lighter’s fuse fixed the problem.
