Sponsored by: CARiD
P001885 Code on 14 E350
Old Feb 26, 2025 | 08:51 AM
bobb00's Avatar
I have P001885 code on 14 E350, I found oil in the camshaft sensor connectors, replaced O-Ring and cleaned it but code still showed up after 2nd start up. Will replacing the sensor completely fix the code? The car only has 77k miles
Old Feb 26, 2025 | 09:06 AM
JettaRed's Avatar
Veteran: Army
What does the code say?
Old Feb 26, 2025 | 10:05 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
"oil-in-harness" to what extent ?
Are all 4x CPS + Lambda sensors + ECU oiled up... ?
Your engine plastics likely damaged by extreme heatsoaks.
Reduce use of ECO: Engine Cut Off's!!
Upgrade engine oiling
Use sacrificial pigtails
Old Feb 26, 2025 | 10:53 AM
S-Prihadi's Avatar
It is P001885
Buy a lottery based on this number Jet, maybe u can get lucky
Old Feb 26, 2025 | 11:25 AM
ChuangTzu's Avatar
19 GLA45, 86 560SL, former: 14 E550 4Matic, 09 E350 4Matic, 83 240D manual, 78 450SLC, 81 500SLC
Did you check your connectors at the ECU side of the wiring harness for oil?
Old Feb 26, 2025 | 11:35 AM
JettaRed's Avatar
Veteran: Army
Originally Posted by S-Prihadi
It is P001885
Nah, I just get tired of brand new members asking for help without providing a description of the DTC. I'm not interested in chasing down the description. I've only memorized through P001884. And my remote viewing capabilities are geofenced to within 10 miles of me.
But, this video may be helpful...
Old Feb 26, 2025 | 12:03 PM
bobb00's Avatar
Yes, No oil at all
Old Feb 26, 2025 | 12:04 PM
bobb00's Avatar
Yes No oil at all
Old Feb 26, 2025 | 01:54 PM
ChuangTzu's Avatar
Did you also check for oil in the magnet connectors?
Old Feb 26, 2025 | 02:51 PM
bobb00's Avatar
Old Feb 26, 2025 | 04:10 PM
bobb00's Avatar
I haven't, I will check them. I replaced both camshaft position sensors not too long ago and cleaned the connectors and the car starts perfectly every time with no code 10+ times UNTIL I rev the engine or put it into Reverse or Drive then the code pops back up and hesitates to start unless I clear it. Is this a good sign? Can it be the magnets that are bad or where should I go from here?
Old Feb 26, 2025 | 04:45 PM
ChuangTzu's Avatar
First step is to check if there is oil in the magnet connectors. If there was oil in your position sensor connectors, I would replace the sensors, not just the o-ring. If there is any oil in the magnet connections, I would replace the magnets as well, not just the o-rings. Checking the connections for oil is very easy.
Next step after changing the sensor for that bank is to change the cam magnet as well. If you change the sensor and the magnet, and you still get the code, you will need to remove your front cam cover and diagnose/replace from there.
Old Feb 26, 2025 | 04:47 PM
bobb00's Avatar
Ok, Thank you I will try and let you know what happens. Also, just want to double check. Bank 2 is the passenger side correct?
Old Feb 27, 2025 | 12:38 AM
Bank 1 is Alternator side
Bank 2 is A/C compressor side
