Sponsored by: CARiD
Shift into park question
Old Feb 26, 2025 | 03:07 PM
derekwh's Avatar
2012 E350 Bluetec, 2014 GLK250, 2007 CLK350 convertible
My '12 E350 won't shift in Park when using the stalk shifter button but it will shift into Park when opening the driver door. This is a relatively new problem because it used to shift into Park okay. There is no problem shifting into Drive or Reverse. Any thoughts?
Old Feb 26, 2025 | 03:08 PM
Arrie's Avatar
Bad button.
Old Feb 26, 2025 | 03:49 PM
derekwh's Avatar
Is it repairable or do the whole stalk assemblies have to be replaced?
Old Feb 27, 2025 | 02:53 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
you will need to use a scanner to query faults... likely a marginal SCM networking issue mixed with unstable voltage.
Long story short: rebooting the chassis should fix soft-cradhed SCM temporarily chance for No parts needed...?
Just never bang on steering column when tilt gets stuck.
Old Feb 28, 2025 | 11:47 AM
derekwh's Avatar
Is this where the steering wheel is turned lock to lock and returned to center with the engine running?
Old Feb 28, 2025 | 01:56 PM
Nope, steering side to side was used to reset positioning sensor. These days are gone. SVM is self centered.
Old Mar 1, 2025 | 01:45 PM
derekwh's Avatar
Is there a link for doing this?
Old Mar 1, 2025 | 01:57 PM
yes, actually there is...
here is a way to reboot and float your battery up if you want.
Old Mar 1, 2025 | 02:03 PM
W205C43PFL's Avatar
Is this the same thing? https://mbworld.org/forums/w212-amg/...ml#post9120249
Old Mar 1, 2025 | 02:13 PM
It seems similar but uses different circuitry and different failure.
The AMG is not attached to steering column. It ises its own solderless module.
The non-AMG relies on SCM steering module to provide failure.
W205C43PFL's Avatar
never mind should had refreshed the page before commenting.
Old Mar 1, 2025 | 02:14 PM
W205C43PFL's Avatar
You are fast in typing : ) I should had refreshed again, since now I just saw this post : )
Old Mar 1, 2025 | 02:18 PM
STANDARD FAILURES GALORE
I know it is confusing - It seems all W212 PRND selectors must fail regardless AMG or standard.
That's not even involving the ISM Solderless shifter module: a "security dealer only" item.
Old Mar 1, 2025 | 02:24 PM
W205C43PFL's Avatar
Head scratcher for sure.
