Sponsored by: CARiD
Steering Squeek After Driving
Old Mar 13, 2025 | 05:58 PM
Rangebyte's Avatar
2010 W212 E350, 2024 Jeep Wrangler 4xe
Question Steering Squeek After Driving
Got a 2010 E350 Sedan recently, put some money into routine maintenance (fluids, filters brakes etc), but not been able to pinpoint an annoying, somewhat intermittent steering noise. It sounds like rubber on rubber and only manifests after the vehicle has been driven for extended time (like >20 miles/mins). I've seen people saying its the steering column, ive seen people say ball joints. Anyone got any recommendations before i point a mechanic at it again? Last time they took it in they said they lubed some rubber components but made no difference.
Other than this and a few interior rattles, the cars great and I hope to keep it to 100k+ miles (75k at the moment).
Vid of noise:
Old Mar 14, 2025 | 02:47 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
this sounds like the dry steering column bearing gone bad.
The MB specialist won't need directions to diagnose your column.
As for steering oil service while you're there. Check the seasoned high pressure hose fittings for leaks.
Old Mar 14, 2025 | 12:49 PM
Rangebyte's Avatar
Thanks, what is the dry steering column bearing. Im not seeing that when i search.
The steering was serviced (fluid/reservoir change) and pipes inspected. They were good.
Old Mar 14, 2025 | 01:51 PM
it's located right at the top of steering column, under the steering wheel.
Old Mar 14, 2025 | 04:31 PM
W205C43PFL's Avatar
Vid of noise:
https://youtube.com/shorts/qYASZ2yj9KM
There is this TSB, not sure if it applies: https://static.nhtsa.gov/odi/tsbs/20...33783-0001.pdf
Old Mar 14, 2025 | 04:32 PM
W205C43PFL's Avatar
Interesting, is it common on the W212?
Old Mar 14, 2025 | 11:50 PM
simple chaos setup
MB builds the steering column steel ball bearing with plenty of attention to preset ownership experience.
What I can say... is once I lubed my dry column bearings, I noticed the difference: steering wheel feels lighter to steer. (**)
factory dry condition👏
dry factory lubed condition👏
Here is the related thread for ya... I was surprised by the dry bearings in my luxury German vehicle. What a setup!!
both bearing races after getting lubed with high-temp silicone
I have since bypassed the aggravations from the monkey tilt convenience... so we could fix something more interesting:
the laggy heavy hot factory setup.
**: I van write a chapter how MB steering wheel handling gets degraded by:
steering column dry top bearing
dry struts ball bearings races (2pcs)
weak ball joints at knuckles (4pcs)
these parts are amazingly cheap, only need TLC.
Old Mar 15, 2025 | 10:04 AM
W205C43PFL's Avatar
Old Mar 17, 2025 | 06:59 PM
Rangebyte's Avatar
I’m now hoping this is ball joints and not the steering column needing to be taken apart. I feel an expensive repair on my hands if that’s the case
Old Mar 17, 2025 | 07:26 PM
you know you can inspect these ball joints... or take a guess based on mileage and age.
Forward control arm with ball-joint is the second suspension part to wear out after stab-links ball-joints. Replace all 4pcs.
Old Apr 15, 2025 | 06:01 PM
Rangebyte's Avatar
Hi All,
Turns out it was the struts, i suspect the top mount was the issue but needed to be replaced anyway due to some minor leaking. Silent now!
Old Apr 16, 2025 | 03:46 AM
BenzV12's Avatar
W212 FL
Thanks for your feedback on your issue. Sometimes , mine squeaks as well
Happy Driving
