Sponsored by: CARiD
Disabling the door lock rod?
Old May 9, 2025 | 02:26 PM
hunch1969's Avatar
2010 E220 aventquard S212
Hi I live in the UK and have a W212 estate. It has the standard tinted side and back windows which are great at preventing people looking in, but uk law doesn’t allow for the front driver/passenger windows having a tint.
I’ve just suffered my 3rd opportunist theft from the car in the last 4 years. Around my area we have regular tea leafs who walk the streets at night looking to see if some idiot (me) has left their car unlocked by looking to see if the door lock rod is up. so, I need to come up with a practical measure to get around my stupidity and make it harder for the tea leaf to notice if my car is unlocked.
Does any one know if it is possible to disable the lock rod from rising? I suspect it can’t but thought I’d ask. I can’t think of any time in the last 10 years I’ve ever used the rod to lock the door.
As I doubt the rod can be disabled, I was wondering if I can put a patch of tinted film on my car window and will it go up and down ok without getting damaged? Technically it’s illegal, but I figure that a small area of a few inches by the rod would make it hard to see if the rod was up or not in the darkness when they are doing their walk byes and the police would probably turn a blind eye to such a small area of film. I have no technical knowledge so just trying to figure out a plan.
rhanks
Old May 9, 2025 | 02:54 PM
W205C43PFL's Avatar
rhanks
not too sure but...
Try unscrewing it in the up position?
Then put some tape over it or something?
Old May 9, 2025 | 04:02 PM
Arrie's Avatar
rhanks
This rod is for unlocking purposes. You normally lock/unlock using the buttons but how about if you have an accident and electric stops working and car is on fire?
Old May 9, 2025 | 04:52 PM
hunch1969's Avatar
A fair point, although the Handle inside the car would still open the door without the rod. I guess I should look at obscuring the window as a first try
Old May 9, 2025 | 07:36 PM
Arrie's Avatar
My car door does not open from the handle if the door is locked. Perhaps this is different between Europe and the US.
Edit:
I must take the above back. My car doors do open from handle when they are locked.
Edit 2:
The front doors open from the handle when locked but the rear doors do not. Rear doors needs to be unlocked by some means. The handle does not work without first unlocking.
Old May 9, 2025 | 07:47 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
I’m in the US. Many euro cars have a double pull on the handle in case of emergency such a going underwater. I personally first had this a quarter century ago in and Audi 1.8t. Each euro car owned has had it since. I’ve owned has had it since. My w212 will only do this on the driver door first while running in park or drive while locked and the rear doors will open with a double pull after the driver door unlocks. Last year I was explaining to a friend in the rear seat that they shouldn’t pull up on the pin because it’s plastic and they could damage it and all they had to do was do a double pool on the handle and it didn’t work and that’s when I went investigating.. and honestly, it doesn’t make sense to link it to the front door because if the electronics fail, you need the mechanical linkage to not fail….and it’s a plastic pin on mine. Not sure if everyone’s works this way but I literally took apart the door to see if the child lock was broken.
Old May 10, 2025 | 07:49 PM
Baltistyle's Avatar
Since I can’t edit…when in drive and locked the double pull will work on both front doors and when either of them open the others unlock. I know it isn’t a huge deal detail, but I remember being amazed in my first car with it because I thought it was so genius and German for the safety aspect..
Old May 10, 2025 | 08:08 PM
Arrie's Avatar
Yes, the other doors unlock as long as electronics work but you may be out of luck in an accident and doors will not electronically unlock. In that case the only way to unlock rear doors is to pull the rod up.
Old May 11, 2025 | 10:29 AM
W205C43PFL's Avatar
Ya unfortunately that was a change since last year, you can't edit pass a certain amount of time.
Old May 11, 2025 | 11:39 PM
Pantomime's Avatar
2016 E350 Sport
Making sure your car is locked could spare you all that headache!
Old May 12, 2025 | 08:50 AM
W205C43PFL's Avatar
Yes that lock rod as OP calls it as a sign, folded mirrors (is usually a sign, assuming didn't manually fold it in), a flashing red light in the centre console (or does the W212 have it somewhere else, can't remember) is another sign. Double pressing the lock button to disable the key fob then pulling on four door handles can confirm if the vehicle is locked.
Old May 12, 2025 | 09:38 AM
DFWdude's Avatar
2016 E350 Sport
I can't imagine it took until post #10 before someone posts the actual solution.
On my US W212, I exit the car, close the door, and simply touch the square molding on the outside handle. Car is locked, all pins are down. A habit as easy to develop as pressing a lock button on the remote.
Old May 12, 2025 | 09:51 AM
DFWdude's Avatar
2016 E350 Sport
As a practical matter... The plastic lock pins are functional (as well as decorative) because they locate to metal rod through the holes in the door trim. If you remove the pins, you will see very little of the locking rod in the hole in the locked position. It's possible for the rod to fall out of position -- into the door -- blocking the ability to unlock the door, at all.
You can screw the pins further on the rods, which will give the impression that they are lower in the holes. But it's still a poor camouflage substitute for actually locking the doors.
Old May 12, 2025 | 05:01 PM
W205C43PFL's Avatar
Hmmm, I thought OP was concerned about thieves pulling the pin up didn't occur to me OP's door wasn't locked, I do apologize about that.
Old May 12, 2025 | 05:02 PM
W205C43PFL's Avatar
That is interesting, I wonder if there are shorter pins to be installed then if tightening it further isn't short enough.
Old May 12, 2025 | 07:31 PM
Arrie's Avatar
I just can't believe someone wants to jeopardize rear seat passengers for being sloppy locking the car. Explain this to people who were trapped in the rear seats when the car burned and nobody in outside nor inside had a tool to break a window...hey wait, you can't ... they burned DEAD!!!
Old May 12, 2025 | 07:44 PM
W205C43PFL's Avatar
Scary stuff to think about
