2013 E350 E212, car moving forward when shift in "N"
What could be the issue? might be related to the changing rear flex disc?
If you're looking at stoping wheels shift to the Parking selection.
Tranny oil level must be correct given warmed up condition + engine running.
Use clean genuine ATF of matching grade/color to level as per MB procedure.
(Beware: wrong fluid level or condition can damage tranny internals: ~$8k)
The transmission fluid was Fuchs 72229Late from FCP EURO. It was changed about one year ago. Fluid was leveled at 45 'C degrees till on-continuous dripping.
Then tranny level is good (flat garage floor?)
Sounds like your tranny is not shifting into Neutral.
Can you hear the ISM Module clunking each of your PRND gear selections?
Or is nothing happing due to failing ISM ?
ISM built to nequire service.
> Next you'll confirm ISM status directly reading it with your scanner: 5mn answer.
I checked my other three cars, all can be shifted to "N" with or without engine running and car did not move when in "N". I think something wrong with the transmission/shift when I changed the rear flex disc. I will let dealer check it out.
