Sponsored by: CARiD
Strut rod bushing R&R (right side)
Old May 23, 2025 | 02:15 PM
mercerized's Avatar
2020 E450 4matic wagon
Hello forum members,
According to the WIS attached, MB tool 212589004300 is used to press both sides (ref. steps 5 and 6).
Pressing from both sides does not appear to be necessary unless the inner rubber seal gets further seated when using MB cups.
Has anyone pressed in their strut rod bushing using the MB cups?
Old May 23, 2025 | 03:29 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
front control arm
You're replacing the bushing on the front control arm.
suspension No1 wear item
suspension wear item
How many miles on your ball-joint ?
How to replace BJ ?
Old May 23, 2025 | 04:21 PM
mercerized's Avatar
135k mi. Already replaced the elasto bushing.
Question is the pressing from both sides.
Old May 24, 2025 | 04:07 AM
S-Prihadi's Avatar
The baby ball joint at the end of the arm will also wear out, when and if the bushing you are discussing needed to be replaced.
So replacing the entire arm is better...yep cost more.
