Sponsored by: CARiD
Sharp edges behind Bank 1 and Bank 2, M276.8 3.0TT
Old Jun 25, 2025 | 11:31 AM
S-Prihadi's Avatar
I guess M276.9 3.5NA would be the same..............
I got a nasty cut today at Bank 1 ( Right side bank ) rear azz. The engine block gave me its middle finger
The cylinder head gasket is on purpose having extra edges protruding out , be very careful, that is a metal thin gasket, like razor blade.
This is above the crankshaft position sensor, Bank 2, LEFT side bank. The Right side bank would have similar protrusion, be careful.
I was deep cleaning my engine rear azz, Bank 1 Right side, because I replaced the PCV system.
The cable clamp also is a risk for fingers.
Above cable is for connector X26 at the PCV centrifuge black plastic casing.
I do not wear glove because I can't feel the nook and cranny
I did wear my sleeve-elbow protection , but not the glove.
Stay safe...........
Old Jun 26, 2025 | 05:36 AM
tesna's Avatar
W212 E300 2010
ouch! I hope it will heal quickly!
Old Jun 26, 2025 | 11:59 AM
S-Prihadi's Avatar
It hurts bad, wide cut. Worst cut to date for the session. Usually rub cut, this one is direct cut.....
Thanks for the healing wishes
Old Jun 26, 2025 | 03:53 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
ENGINE CUTS FINGER
sorry to read about your deep cut... the engine is fighting back all your good care!
Your engine is super clean.... looks goood.
