Sponsored by: CARiD
Quick and Dirty intake valve cleaning - 2nd time
Old Jul 9, 2025 | 12:18 PM
S-Prihadi's Avatar
Sharing........
1st time was Aug 2022. About 35,000 KMish. Here : https://mbworld.org/forums/e-class-w...eaning-p2.html
Below work is 43,000KM ish or 9,000KM later.
Since I got time and intake manifold removed, so I did intake valve cleaning again and this time VERY FAST.
Only 2 hours all these took and some only need B&G Air Intake Cleaner & Valve Cleaner liquid I had from 1st job + STP carburator cleaner, using lint free cloth as wipe.
Some cylinders need the 3M very fine brown scotch brite, like below :
Back in 2022, for reference. Cylinder 1. Below :
ABOVE is Left side valve, Aug 2022, 35,000kmish.
BELOW is Right side valve. Aug 2022. 35,000 KMish
I don't need it to be super clean.
As long as there is no build up higher/thicker than 0.2mm, I am fine. Airflow won't be disturbed.
Old Jul 9, 2025 | 02:54 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
valve inspection
MS your intake valve deposit layer is really minimal especially with your boost pressure.
Seat leak is more important for balanced compressions, right?
Old Jul 10, 2025 | 03:38 AM
S-Prihadi's Avatar
There is no seat leak.... easy to test with boroscope and flooding the valve with cleaning chemical.
But if in a year or two will I tear down the engine....... valves will get proper cleaning and seating test and the cylinder head + piston carbon be cleaned
