Sponsored by: CARiD
Pressure in the fuel low pressure circuit, is too high.
Old Jul 24, 2025 | 08:19 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
TWO THUMBS UP
Originally Posted by ISMAELX
@CaliBenzDriver You Are The Man!!!!
Problem fixed!!
I received the FSCU module yesterday and proceed to install it, but first using this Launch Creader Elite 2.0 MB scanner, I back up coding from old FSCU then disconnect battery, replace FSCU, reconnect battery, restore coding, clear all codes with scanner, run scanner again and no more codes.
I drove the car for a few miles this morning, when I got home connect scanner again and no codes.
Checking live data, fuel rail pressure now shows 57 psi.
Great you are the man who did all the hard part...
I just help you with hints and steps.
Remember that you need to locate the source of water to disable repeat game installments.
It's always about ROOT CAUSE!
Old Jul 24, 2025 | 08:48 PM
ISMAELX's Avatar
2010 E350
Yes the water source has been fixed, I purchase this FSCU used from Ebay, same part number, same everything on the module label but was removed from 2011 E550, mine is 2010 E350, the back up and restore of coding went really smooth, I like this scanner!
Main Fuel pump which is under rear seat passenger side, is now quieter, I think the bad FSCU was causing the noise in fuel pump.
In my research about fuel filter discover that the fuel filter is also a secondary fuel pump, which is located under rear seat driver side, I haven't replace that, do you thing it will be a good idea to replace it?
Old Jul 24, 2025 | 10:34 PM
ChuangTzu's Avatar
19 GLA45, 86 560SL, former: 14 E550 4Matic, 09 E350 4Matic, 83 240D manual, 78 450SLC, 81 500SLC
How many miles did you say were on the car?
If you replace the module under the right rear seat, also replace the one under the left rear seat. You'll probably be going back in there again soon if you don't. It's 3x more work to replace 2 of those modules separately, and only 1.5x more work to replace them both at the same time compared to one. At least the way I did mine. This is because they connect to each other in the tank and you need to pull them both at least partially to do either one.
Old Jul 24, 2025 | 11:58 PM
Your fault was totally external and not related to tank items.
You can leave the standard tank troubles alone for now.
Or
you can spend ressources on tank items that are not due for service. I would not.
Old Jul 25, 2025 | 11:04 AM
S-Prihadi's Avatar
Its not actually a secondary pump, it is a venturi effect "pump" ( no motor, just a venturi ) to make sure RIGHT side tank where the fuel pump is, is aways full of fuel....so that pump does not get fuel starve.
Yes, you MUST replace the fuel filter on the LEFT side of the tank, now ur car is 14ish years old.
You cut it open and you will be surprised how dirty it can be.........
Stay safe when doing fuel tank yah.....
Old Jul 25, 2025 | 12:06 PM
ISMAELX's Avatar
2010 E350
I guess you're talking about fuel pump and filter, what I did replace was the FSCU, it's fuel control module located outside the fuel tank
Old Jul 25, 2025 | 12:10 PM
  #32
ISMAELX's Avatar
2010 E350
Thank you for clarified that, Always learning something
Old Jul 25, 2025 | 12:15 PM
  #33
ISMAELX's Avatar
2010 E350
Thumbs up
Or
Thank you again for your help and advise, you are the man!!!
