Sponsored by: CARiD
2011 E350
Old Aug 21, 2025 | 02:29 AM
pearson1223's Avatar
2011 E350
2011 E350
Car was driven through flood and initially had power removed battery plugged back up battery and now nothing whatsoever no power to case whatsoever Trying to troubleshoot but at a loss?
Old Aug 21, 2025 | 04:11 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
100% total loss
not worth time
recycle.
Old Aug 22, 2025 | 12:04 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Pull front floor mats and carpeting, check for water intrusion
Old Aug 22, 2025 | 01:11 PM
Needs a list of new parts....
  • steering rack $$$$
  • alternator $$$
  • harness/cleaning $$$$
  • (engine fan?) $$$
  • (headlights) $$$$
  • wheel bearings
  • main chassis GND Strap $$
Plus expert hours troubleshooting each systems.
> Cost & results not worth troubles.
Old Aug 22, 2025 | 01:18 PM
Very likely, but not harmful to verify
Old Aug 30, 2025 | 04:00 PM
2011 E350
Got power back the starter was fried fuse 7 was shot. Replaced both of those and now just hear a click at and the cluster goes dark. No water in CAN Bus areas.
Basic scanner gave these DTCTrouble Code(s)
P179A: No description available for this trouble code
B210A: No description available for this trouble code
U0121: Lost Communication With Anti-Lock Brake System (ABS) Control Module
U0100: Lost Communication With ECM/PCM 'A'
U0168: Lost Communication With Vehicle Security Control Module
U113B: No description available for this trouble code
U0111: Lost Communication With Battery Energy Control Module A
P179D: No description available for this trouble code
B2266: No description available for this trouble code
U0415: Invalid Data Received From Anti-Lock Brake System Control Module
Trouble Code(s)
B210D: No description available for this trouble code
Trouble Code(s)
P2066: Fuel Level Sensor B Performance
Video showing what it’s doing:
https://share.icloud.com/photos/0ccF...19bt9TL3fyGlyg
Old Aug 30, 2025 | 05:30 PM
Trouble Code(s)
Trouble Code(s)
Busy long list... which faults are stored vs. active???
Go visit your distribution bus-bars near front doors
Old Aug 31, 2025 | 02:54 AM
BenzV12's Avatar
W212 FL
Water intrusion and electronics are not good friends at all . It could also cause havoc unexpectedly
Old Aug 31, 2025 | 02:24 PM
Code UO100, Your ECU is likely wet or corroded, check connections under front footwell carpets, Many of the other codes may disappear after repairing that one, you may need a rebuilt ECU or you fried one of the fusable links,
Old Aug 31, 2025 | 02:59 PM
A To Z
Pierre,
This is a FLOOD CAR:
ECU + Engine + .....
Old Sep 2, 2025 | 09:02 AM
Pierre,
Likely fatal, It would be a miracle!
Old Sep 2, 2025 | 01:33 PM
MacVidMB-V8's Avatar
W209, W124
Has it had time to dry out yet?
Should not run power through anything until every bit of car bone dry.
When power runs through wet boards it finds shortcuts. And moves ions around, shorting things out permanently. Moist carpet means electronics are SOAKING WET. Would you expect a laptop to keep working if full of water?
You most likely will NEVER get car running again. And even if you do, you will likely have a never ending series of cascading faults and gremlins.
If the car was a 1964, could have easily been dried out and fixed. But with everything now sending low voltage signals to a control module that then triggers a relay to energize a circuit, WAY too many things to track down, especially when power run through wet circuits.
