Sponsored by: CARiD
e350 Rumble on cold startup.
Old Oct 8, 2025 | 11:55 AM
abqhudson's Avatar
2014 e350
New to me 2014 e350 sedan has a rumble on startup - slight acceleration.
Goes away after warm up.
Is that normal?
All comments appreciated.
Old Oct 8, 2025 | 02:30 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
rattling
Is that normal?
this sounds like you're dealing with start-up rattling. This is caused by failed VVT phasers near 100kMi. Standard repair with CPS "oil in harness" at the same Time + tensioners.
What is your local MB specialist saying??
Old Oct 8, 2025 | 04:38 PM
abqhudson's Avatar
2014 e350
Thanks.
Hasn't been in yet (will need an A service within the next month).
Does not sound like a metallic rattle to me.
Old Oct 9, 2025 | 05:00 AM
Thanks.
good it will be repaired soon by the best crew
Old Oct 9, 2025 | 09:12 AM
JettaRed's Avatar
Veteran: Army
Is that normal?
What do you mean by "warm up"? Engine warm up to operating temperature can take several miles and 5 to 10 minutes, depending on the start up temperature. If you mean the 10 seconds or so from cold start until the rpm stabilizes, that is different. I have the same engine with 130,000 miles and no rattle at start.
