Sponsored by: CARiD
2010 E350. crazy clock
Old Oct 14, 2025 | 05:03 PM
2010mercedes's Avatar
e350
The analog clock on my 2010 E350 does this every minute or so. Clock toys to reset even when the car is parked. Clock tries to reset almost every minute. The clock on the command center hs the correct time. Any ideas on what could be causing this. Tried the main battery disconnect and that did not fix the problem.. Main battery reads 13.1v. and 12.8v under load and is fairly new.
Old Oct 14, 2025 | 05:12 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I have 2015 model, so not sure it is the same, but I still remember dealing with it 6 years ago, when I bought it.
You need to synchronize cluster with command center.
I don't remember the details, sorry.
Old Oct 14, 2025 | 09:13 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
NOT TIC TOC
the classic dash-clock is a module complete with network COM's.
Fortunately or unfortunately it's already soldered reliably. That leaves fewer possibilities for a fix...
Your local MB professional may consider :
  • troubleshoot shared bus issues
  • replace (used/new) clock module
  • set to twelve-noon + disconnect
All valid options...
