Alternate jacking points for 2014 E350
If you need the entire car higher when using the ramps just use the normal jack points and raise each side to stick another plank under the wheel then lower it back down.
My area is gravel and do not trust being under the car using jack stands.
If you do not yet have MB jack adapter for jack stand with U shaped end, do get it, safer that way.
Something like below :
Check you harbor freight jack type/model number and year made, there were some recalls.
https://images.harborfreight.com/hft...1196_61197.pdf
https://www.nhtsa.gov/press-releases...ck-stand-users
Stay safe under the car.....
I would only use the front middle jacking pad on the front subframe. I dont think the spots at the control arms are designed at all to hold up the weight of the car. Its just stamped metal. If you stick jack stands under the control arms themselves I dont think the bolts will hold or will at least get bent.
In the rear I have placed jack stands under the subframe where the spring arms mount. But that was just for back up as I had a floor jack on each side plus jack stands. I would just place them there in case, would not lower the car down on to them. I have extra jack stands so why not use them.
I have two floor jacks, 4 jack stands, wooden ramps with a bunch of extra planks, then I have large pieces of wood timbers i'll place under the car. I go overboard so there is no possible way the car can fall on me. I have some sections of 4x4's i'll shove under the arms of the floor jacks so they cant lower in case the jack were to fail. I also have two scissor jacks that come in handy sometimes for holding up the exhaust or raising a wheel carrier to align suspension bolts.
If you have to go under the car and the wheels dont have to come off I say use ramps.
Front 4matic subframe. Use jack pad location only.
Rear subframe upside down in photo. I've placed jackstands at red circles. The car already has to be secure in the air to get under safely. I would not use those areas to jack up the car though.
Be careful using that jack pad pictured up there. I just had mine break in half the other day, and it didn't look as ratty as that. Sent the jack straight up into the engine bay. Fortunately, I had jack stands in place already, but still did some damage.
the unmarked black ones are my oldest.
Thanks for the advice.
