Sponsored by: CARiD
Profiling the battery state of charge & Ctek charging profile
Old Nov 22, 2025 | 04:24 AM
S-Prihadi's Avatar
Sharing.........
This is a spin-off from this thread, sort of : https://mbworld.org/forums/e-class-w...200-ancel.html
Due to bedding my brake pads on dyno mode the past 10 days, I needed many short engine run and door being kept open for a very long time.
So I got a chance to see fluctuations of battery state of charge and so on.
337 data points above if I recall , it was me scanning the car using Xentry and I did not use my battery maintainer.
The Ctek charging profile is very visible when logged this way at 1 data points per 2 minutes.
The conclusion is, if you own a Ctek charger, even if you use your car often, it is good to charge it once a week after engine OFF at least 12+ hours , or engine thus battery ....already at ambient temperature.
Even with ALTERNATOR-LIN disconnected , or worse eco style charging mode with alternator LIN still connected, alternator is a DC power generator and not a proper 3 stage smart battery charger.
The last 20% charging a lead acid battery, which is 80% - 100% state of charge, is always the time consuming one. Minimum 4 hours is needed at very slow declining amperage.
Can't do anything about it, it is the battery chemistry natural behaviour.
For me, opening doors often is the extra drain and the extra 38 milliamps my Banks Gauge and XBB Headlight Command module is consuming is another thing I need to consider.
My Banks Gauge now is a dual unit, not single. I have not measure its power consumption during sleep.... for a dual display.
If I see my battery at 12.50V in deep sleep mode, I will charge it.
The beauty of the cheapo Ancel BM200 is its wireless and logging function.
Happy maintaining your battery guys..............
SIDE NOTE ;
I am going to get Ancel BA101 Battery Tester, as a 2nd re-visit owning such device, electronic battery tester.
I have the Konnwei, below ... and its not so good.
Too bad this test below did not include the higher end Midtronics MDX series.
However I am so suprised to see US$300 Midtronics PBT Series jurassic park which turned out to be so dumb
TopDon being anothet dumb azz is also a big suprise.
I still only trust my analog load testing, but hopefully the Ancel BA101 Battery Tester will do better than my Konnwei and I can use it as 2nd reference to my analog load testing.
I will not pay US$700 ish for higher end Midtronics, no way in hell.
Old Nov 22, 2025 | 10:20 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
CTEK FLOATED AGM
It's very interesting to witness how very sensitive these cars are to battery charge level.
A lot of us know ALT is the running chassis power source and battery supplies NO power while engine is running engine, right?
How can these chassis sense a difference between battery state of charge: as-is charge vs. CTEK floated up (stable ALT-LIN=14.15VDC) ??
I'm still puzzled by this enigma that's impacting chassis performance. What ever issue is causing this makes ALT-LIN an interesting experimental solution towards stability.
Long story short is the best SOC is CTEK floated-up.
HK Style: S500 with Distro+
HK Style: S500 4M with DistroPlus in RHD ✌️
Old Nov 22, 2025 | 10:54 PM
S-Prihadi's Avatar
Time is not our friend when car is driven ....as far as alternator charging battery to true 100% SOC, unless during long range run.
The Ctek amperage profile.
