Sponsored by: CARiD
Repair of side radar modules
Old Nov 24, 2025 | 08:13 PM
dave2001auto's Avatar
84 300d 2009 e320 bluetec (retired)/, now 2012 E350 4-matic blueefficiency automatic
I have an bad rear side blind spot radar module 0009050110 located the side of the bumper wrap. Are these modules easily repairable? Can be cut open and parts are not encased in epoxy or hard to remove material?
What the common failure on these modules?
What's the changes of a used module will be good on ebay?
I guess that I should swap out the bad left to the good right and vise versa to see it it is the module or wiring.
Thanks,
Dave
2012 e350 4-matic
Old Nov 24, 2025 | 11:51 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Fatal Water Penetration
Thanks,
Dave
2012 e350 4-matic
It's both the harness and the module that are involved in water penetration.
The internal electronic are built without effective protection so that any amount of water develops terminal oxidations.
Old Nov 24, 2025 | 11:56 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Easy to swap around. But, if you get a new one it will need Paint
Old Nov 25, 2025 | 03:30 AM
Arrie's Avatar
Thanks,
Dave
2012 e350 4-matic
Happened to me. The driver side went bad. Swapped between sides and the problem followed. Bought a used one from eBay but it was faulty, returned.
Bought a new one from MB dealer, all good.
My sensor did not show any external damage at all. No signs of water getting in it or damage at harness. It just went bad.
Hardest part of the job is to get the harness off of the sensor. I did the first swap taking the bumper cover off but then installing first the eBay sensor and then the new one I did without taking the cover off and it was hard for that harness connection part. Not much room to work with, but doable.
Old Nov 25, 2025 | 11:59 AM
Any technique to release the connector from the sensor?
I have seen some chinese sensor with the same part number but has works only on 2009 and earlier. Firmware not updated?
Old Nov 25, 2025 | 05:33 PM
Arrie's Avatar
Very small hands. There just is no room.
