Sponsored by: CARiD
Torque values for replacing belt tensioner and pulleys
Old Nov 28, 2025 | 03:53 PM
waves's Avatar
2011 E350 M272.980
Got the FB0034K set from Rockauto and looking to replace the belt, tensioner and two pulley but I can't find the torque values. Can anyone help me with this? 2011 E350 base sedan with M272.98 engine.
Old Nov 28, 2025 | 05:50 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
new vs. existing
I don't have torque data... you'll find screws hardly tightened.
A lot of replacement belts are mismatched straight from Mercedes EPC.
Compare your new replacement with actual length before calling this job done.
Old Nov 29, 2025 | 09:10 PM
Raj1471's Avatar
2011 Mercedes E350 4Matic Wagon
Torque values for the tensioner bolts is 35nm and for the pulleys bolts is 25nm. It is recommended to put a little bit of blue loctite to the all the bolts as well.
Old Nov 29, 2025 | 09:41 PM
TimC300's Avatar
I used 35nm for the tensioner and the ribbed pulley. For the smooth pulley I used the 25nm listed for "follow-up operations".
Old Nov 30, 2025 | 12:50 PM
waves's Avatar
2011 E350 M272.980
Thanks a lot!
Old Nov 30, 2025 | 07:08 PM
waves's Avatar
2011 E350 M272.980
I replaced everything today. It was tough to pull out the ribbed pulley and once out, the washer behind it was severely deformed. I flattened it the best I could and put it back but now I'm wondering if I should buy a new one and replace it or just let it be. The INA belt that came with the kit is a bit longer than the Gates K060945 belt that was on the car but engine runs fine.
Old Nov 30, 2025 | 07:27 PM
TimC300's Avatar
The new pulley should come with everything, you should not have to reinstall anything with that pulley.
Did the pulley come with a new bolt and washer already installed?
The smooth pulley should come with just the pulley, no bolt. With that pulley I reused the old bolt. Mine also has a small washer installed between the engine and the pulley that I reinstalled.
Old Nov 30, 2025 | 07:41 PM
TimC300's Avatar
When I removed my smooth pulley there was a washer behind it. I dont think many others have this washer. I kept it and reinstalled it since the new pulley did not come with anything else, just the pulley.
Old Nov 30, 2025 | 11:46 PM
waves's Avatar
2011 E350 M272.980
Got it, pulled the pulley and removed the old washer. Thank you guys!
