Sponsored by: CARiD
Problem with engine turning over on y ‘10 E350
Old Jan 1, 2026 | 10:13 PM
mike10E350's Avatar
2010 E350
Guys,
All of a sudden my 2010 E350 doesn’t want to turn over at all for some strange reason when I turn the key. It’s not strictly an engine battery problem because the battery is a new MB battery from just several months ago and if I turn the key 5-6 times it eventually fires up. What could cause this?
Mike
Old Jan 2, 2026 | 12:20 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
ESL... OR SCAN
Originally Posted by mike10E350
Guys,
Mike
Mike, do you have a steering hydraulic pump or an electrical rack on your MY'2010 ??
(Let us see a picture of engine from the front towards driver side: pump cover?)
The difference here is ESL or not...
In cars with steering pump, the chassis is guarded by an ESL module to help "prevent theft".
This module is built around a $5 actuator (eBay is your friend!) that expires when challenged.
Plug-in your trusted scanner to read faults from EIS/EZS Module... faults about "mechanicsl failure...".
Without a scanner you can....
hope for luck and try to ease the static steering wheel torque on parked car. Then try turning ignition key ...
Old Jan 2, 2026 | 01:11 AM
BenzV12's Avatar
W212 FL
Fuel pump or fuel sender , fuel pressure could be the culprit , One of my old junk cars (non Mercedes-Benz make ) had a similar problem. I was advised to turn the key to II position and back to 0 and repeat it minimum 5 times and then turn the key all way forward to start it up . It worked well then
