Sponsored by: CARiD
Coolant Flush
Old Jan 6, 2026 | 06:44 PM
Davery's Avatar
2012 E550 Cabriolet 2011 VW Eos 1985 Pininfarina Spider
Coolant Flush
I am needing to do a coolant flush and was wondering about doing it myself. I know without a vacuum I will not be able to flush all the coolant, but how much can I remove by using the petcock at the bottom of the radiator?
Old Jan 6, 2026 | 07:33 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
The radiator petcock will get you about 1Gal.
I don't know about a drain plug on the engine block.
Repeat drain'N fill as you see fit
or replace leaking coolant parts:
  • elbow hose at firewall
  • thermostat
  • water pump
  • radiator
  • exp tank + cap
