Passenger side 360 camera on fritz
Connect your LAUNCH scanner to read an exact fault report.
"Calibrations" are reported as bad...
in other words more likely a software than hardware issue.
If you locate the "calibration" procedure go for it
else reset fault and see how long 360° stays well.
I don't have a 360 system to refer to... perhaps it has a dedicated module managing every individual cameras in the 360 set ??
Scanner tells you which component to focus on..........
Good luck.........
