Driver side carpet wet
I am at a loss right now. I dont see any signs of dripping or staining on the metal from wanter. I don't see anything along the seals either. Any help is appreciated because I am running out of ideas.
Standard water leaks are:
- Loose windshield polyurethane glue
- Open roof metal joints
- Discharge conduit overflow (rubber tip!)
- A/C condensate drain (Courtesy OldMan')
The swampy carpet humidity helps oxidize near by GND post connections AND the CAN bus-bars on front doors thresholds.
By all means DRAIN/DRY the pool ASAP.
Then pinpoint the source using bottle of water from the bottom up.
Use a tarp (or shipping tape) to cover roof joints...
Thanks, I have not checked that one. It will be the next thing. Would that still leak if the car hasn't been driven?
The discharge conduit overflow, I'm assuming you mean for the sunroof which I have taken care of already.
A/C Conduit drain, thats the next thing I am checking.
At this point I don't have the room to start stripping the whole interior (no garage). My question is if anyone has any ideas on where I should check next. If not, this may be getting to a point where I have to involve a shop which I fear may be more costly than the car is worth anymore.
Is this a sedan, right? Not a wagon.
- open the rear trunk
- observe the rubber seal
- it goes from side to side
- Look at the space between rear windshield and rubber seal...
- This space across the car width acumulates water while home, right?
- that water needs to be released somewhere....
- likely inside the trunk rushing towards the front floor space.
Hope this helps.
Low probability, but possible water leak source at driver side.
Front SAM plastic fuse box housing gasket has gone bad.....
The opening of this front SAM fuse box at firewall , at driver side under steering.....is in red circle.
Good luck........
-------------- Right Hand Drive Car - RHD ---------- mine
Rusty stud of Front SAM fuse box, from water which has no way to drain out.
Buying time........minor water protection ...LOL
This is where that opening to firewall at front SAM fuse box plastic body...you can see inside the car. The grey wire with yellow tape is spare wire I placed inside the car.
More water/rain drip protection......... for front SAM fuse box.
Crude but it helps
Good luck finding the water leak...
Hope this helps.
Anyway, I dried up what was there, re-attached the hose and I guess I'm back to a wait and see for tomorrow.
If there is wetness there, it could be front sam fuse box.
I can't remember the grey insulation at that hole ( interior side ) is the water wicking type of insulator or rubber based.
