Sponsored by: CARiD
Disabling ECO
Old Mar 23, 2026 | 08:45 PM
MBXfire's Avatar
E350 Sedan, SLK320, XFire Roadster
Disabling ECO
I recently purchased a Launch Creader elite V2.0 which I am a newbie at using. For starters some guidance is needed on how to disable ECO.
Old Mar 23, 2026 | 09:26 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
You need to poke around to discover what settings your particular car is exposing - This HACKING is not obvious nor straight forward.
Old Mar 23, 2026 | 09:28 PM
You need to poke around to discover what settings your particular car is exposing - It varies by year, chassis and engine.
This HACKING is not simple.
Old Mar 24, 2026 | 02:54 AM
ygmn's Avatar
2015 E400 Sedan
some older threads cover this step by step
Old Mar 24, 2026 | 12:01 PM
Pantomime's Avatar
2016 E350 Sport
Try this!
https://mbworld.org/forums/e-class-w...-reader-2.html
Old Mar 24, 2026 | 02:50 PM
poke around as much as needed ... it's well worth fixing.
> Suggested course...:
Tag along it's easy to get lost. Nobody elses car options match yours.
-- Inventory what "variant coding" options your chassis has (many different implementations)
-- BACKUP or note down your original settings.
-- Experiment what you want:
  • Try the new settings
  • Take notes of what you're changing
  • Test as needed.
  • Repeat setting
You need a simple way to back-track on your own if something goes wild
else you will need to pay a specialist to SCN your issue back to factory specs for YOUR OWN VIN OPTIONS.
Many ppl have done this successfully.
Old Mar 25, 2026 | 08:56 AM
streborx's Avatar
Top Answer: 1
G550
But if you're not comfortable doing the coding yourself, even with the info provided in the threads on this forum, find a gearhead in your local MB car club chapter to lend a hand.
