Sponsored by: CARiD
leak water pump inlet tube 2762000156
Old Mar 28, 2026 | 12:37 PM
celyl888's Avatar
E350,GLK350,Ducati
I paid for diagnostic $182 bux but they can't pinpoint the leak. It's replace the water pump $1450 bux. I think the leak is water pump inlet tube 2762000156, it's plastic and from my research prone to crack overtime. Anyone replaced just this piece?
Old Mar 28, 2026 | 12:40 PM
celyl888's Avatar
E350,GLK350,Ducati
Here is a bigger pic #8 and #9
Old Mar 28, 2026 | 12:51 PM
celyl888's Avatar
E350,GLK350,Ducati
Old Yesterday | 05:54 AM
S-Prihadi's Avatar
I have replaced all of the plastics and rubber hose of my car/engine entire cooling system, including thermostat set and radiator and engine oil cooler too.
Here Part 1 : https://mbworld.org/forums/e-class-w...m-refresh.html
Here Part 2 :
Very long post if you like reading : https://mbworld.org/forums/e-class-w...s-after-4.html
This one will crack too : https://mbworld.org/forums/e-class-w...ot-2-them.html
I replaced a lot of things, to keep my car like new.
If I show you more of what I have replaced, you may faint.
Target is to keep it to at least to its 20th Bday.
Now it is 12th year old......... very low mileage my car, only 44,000KM max today.
But plastic and rubber MUST and WILL age overtime. No escape.
MB choosen rubber hoses are not bad, many are Kevlar re-inforced..... the plastics I worry more.
Old Yesterday | 08:34 PM
juststeve's Avatar
2012 E63 Wagon
craigslist sale, replace the one part, the single tire, opt. for the cheapest battery, the cheapest fluids and glue or tape that loose molding back on.
keeping the car, replace everything within reason to keep it on the road and reliable.
Old Yesterday | 09:05 PM
AlexMonroe75's Avatar
just had the same issue with my '22 GLE. turns out the o ring on the water pump inlet tube had worn out, causing the leak. pretty easy fix if you're comfortable with some basic plumbing skills, but if not, it's probably worth sending it back to mercedes.
