Recall Campaign 2021020025 FEB21 – 2016 thru 2021 117, 118, 156, 166, 167, 172, 177, 190, 205, 207, 213, 217, 218, 222, 231, 238, 242, 247, 253, 257, 290, 292, and 463 software design of the communication module may fail to communicate the correct vehicle location for the “eCall” in the event of a crash, other functions of the automatic and manual emergency call function are not affected dealer will update the software of the communication module. Recall will be launched in waves. Approximately 1,292,258 vehicles affected.
LI46.15-P-063353 FEB21 – 166, 205, 213, 217, 222, 238, 253, 257, 292, 253 height adjustment of electric steering column adjustment jams in upper / lower adjustment position or it generates a cracking noise when exiting the upper /lower adjustment position (e.g. for Easy Entry function), move fore/aft adjustment to the end position; release jamming of height adjustment by knocking with palm of hand onto top of steering wheel at the same time push adjusting switch downwards; commission driver's seat control unit - control unit software is updated, limit stops are cleared and normalized any renewed jamming is prevented.
LI32.22-P-071495 MAR21 – 213 (w/code 489), 213.2 (wagon w/o 489) message "Max 50 mph" in instrument cluster, check level sensors for correct installation/damage; calibrate level; align/adjust suspension; perform SCN coding to control unit.
LI80.57-P-072708 MAR21 – 205, 213, 217, 222, 238, 253, 257, 290, 463 engine switches off again when re-attempting Remote Start via Mercedes me, update SW in EZS.
Recall Campaigns 2021020015, 2021030017, 2021020036 MAR21 – 2016–2021 117, 118, 156, 166, 167, 172, 177, 190, 205, 207, 213, 217, 218, 222, 231, 238, 242, 247, 253, 257, 290, 292, 463 over-the-air update (“OTA”) will update the software of the communication module for the automatic eCall system on the affected vehicles parts are not required. OTA updates are performed remotely and do not require a dealer visit. Customers can continue to drive their vehicles. If the vehicle has not been driven in four or more weeks – we suggest that the ignition be cycled once to initialize the process, sufficient battery voltage may be required for the software update to be initialized. Dealer can check for successful update via VMI, once successful the vehicle will be closed on a weekly basis starting 3/26.
Service Campaign 2020110015 MAY21 – 2019-2020 213, 217, 222, 290, 167, 463 sealing surface of the connection between high-pressure fuel lines and pumps might not meet specifications fuel residue might/fuel odor might occur, dealer will replace. Approximately 4,449 vehicles are affected.
Recall Campaign 2021040013 MAY21 – 2018-2021 213, 290 AMG 4matic incorrect screw connection at the starter motor could cause the harness from the power supply to the starter to contact the starter housing, dealer will correct. Approximately 493 vehicles are involved.
Recall Campaign 2021040016 MAY21 – 2021 205, 213 coupe/cabriolet, 238, 253, 257, 290, and 463 electrical contact inside the seat position switch of the front seats might not meet current production specifications, dealer will replace the seat position switches. Approximately 8,634 vehicles are involved.
LI54.65-P-072065 APR21 – 213 facelift / 238 facelift with code 235 and 501 erroneous visual or acoustic alert from parking sensors, or parking assist unavailable, calibrate 360° camera system (if installed) then if required re-commission parking system control unit if problem persists replace parking system control unit.
LI46.35-P-072961 MAY21 – 167, 205, 213, 217, 222, 238, 257 all except 4matic, 463 as of 2019 vehicle drifts to the left or right steering system learned values are determined based on the road surface and road conditions, reset steering system learned values via the XENTRY Diagnosis menu "Adaptations - Teach-in processes – Reset coding".
LI82.85-P-072960 MAY21 – 118, 167, 177, 213, 238, 247, 253, 257, 290 with codes 548/549, 365, 801 MBUX multimedia system (A26/17) has no GPS reception zero satellites are being tracked vehicle position icon in the navigation display does not match the vehicle's actual position, using XENTRY check HERMES module (N112/9) actual values to see if there is any GPS reception. If so, identify CRIN number: Ve-Doc - Theft-relevant data - COMAND device number. If CRIN matches attached list perform software update of MBUX multimedia system (A26/17) using XENTRY.
Recall Campaign 2021050012 MAY 21 – 2019-2021 118, 167, 177, 213, 238, 247, 253, 257, 290 MBUX multimedia software might not meet specifications might not start; display might remain black; reboot unintentionally after 50 seconds of initial startup; rearview camera image not displayed or interrupted, dealer will update the software. Approximately 38,833 vehicles affected.
LI46.35-P-064639 JUN21 – 205, 213, 238 except 4matic up to manufacture date 5/30/21 knocking noise can heard at the left front when steering to the left (wheel turned approx. 270° to 360° not full lock) and simultaneously driving over a threshold, replace thrust piece on rack-and-pinion steering.
LI82.85-P-071453 JUN21 – 117, 118, 156, 176, 177, 242, 246, 247, 172, 190, 231, 205, 253, 166, 167, 292, 213, 218, 238, 222, 217, 257, X290, 293, 463 with HERMES communication module (code 360, 362, 364) and Mercedes me connect incorrect time/date in instrument cluster and/or head unit; SOS Service Not Activated message; Mercedes me connect services nonfunctional; Live Traffic nonfunctional, reset HERMES system time using XENTRY lock the vehicle for 5 minutes (allow CAN Bus Sleep) and then take a test drive in a region with good GPS reception for 5-10 minutes.
LI82.85-P-069961 JUN21 – 118, 167, 177, 213, 238, 247, 253, 257, 290 with code 548/549 and 365 upon selecting navigation, the central display may show the following message: "Map data does not match with your system. Please insert a medium containing the corresponding map data", ensure the MBUX software is up-to-date; perform a user data reset ("Settings" > "System" > "Reset" in display; perform SCN coding of MBUX.
Vehicles with code 2U0 car2go Map data update cannot be carried out, before the map data can be updated via USB code 2U0 must be removed from vehicle's data card in Vedoc then re-SCN code MBUX and carry out procedure described above.
LI46.35-P-073051 JUN21 – 253, 293, 213 (with code M005), 238 (M005), 257 (M005), 205 (M005) from manufacturing date 3/1/20 noticeable vibrations at the steering wheel speeds between 40 and 75mph; straight stretches of road and in long corners; with driver assistance systems switched on, perform software update of electric power steering (N68).
LI82.20-P-073063 JUN21 – touchpad dimming function does not work and search lighting is either at maximum brightness or off (dependent on dimming signal) dimming functions of the instrument cluster and head unit display are not affected, replace touchpad if serial # in VeDoc (Vedoc > control units > TPAD > serial number) or part # matches # in attachment.
is the vibration issue finally an issue? im pretty people have noticed it way before 3/1/20....
Service Campaign 2021030010, JUL21 – 2020-2021 213, 118, 177, 247 printed manuals does not current and supplementary booklet may not be present, dealer will correct. Approximately 1,930 vehicles affected.
Recall Campaign 2021060010 JUL21 – 2021 238, 205 cabriolet rear headrests mounting might not meet current specifications, dealer will replace rear seatback guide bushings. Approximately 12 vehicles affected.
Hi every one
I have S Class 350
The easy exit works only in the wheel moves, but the seat stop moving, keep turn the feature on and off but still the seat doesn't move
Anyone can help
Thank you very much for your all efforts and time!
I tried to find one service recall for the widescreen cockpit problem, but I could not find it. Do you know any news about this problem? Thank you
I had this exact issue and the LCD was replaced under extended Mercedes warranty with no quibbles. The new screen feels a higher screen res. Tech did an update as well and the drivers display has a few new icons / displays.
Recall Campaign 2021070017 JUL21 – 2020-2021 213, 222, 253, 257, 290, 463 locking mechanism for the electrical connector on the side-impact crash sensors might not meet current production specifications dealer will replace sensors. Approximately 542 vehicles affected.
LI82.70-P-073025 AUG/21 – 223, 213, 238, 257, 206, 118,167, 177, 205, 247, 253, 290 with code 897 and/or 899 insufficient charging or no wireless charging with iPhone 12, perform software update of phone cradle for driver's side (N123/8) and if equipped, rear (N123/11).
LI82.85-P-073387 AUG21 – 213, 238, 118, 167, 177, 247, 253, 257, 290 MBUX dashcam temporarily inoperable icon may not be present and/or camera unavailable, update MBUX multimedia system software.
LI18.00-P-073137 AUG21 – M256 engine oil pressure message in instrument cluster, Install new directional control valve.
LI82.85-P-073418 AUG21 – 213, 238, 257, 118, 177, 247, 253, 362 with code 077 (HERMES dummy module) Mercedes me connect services including emergency call system (eCall) restricted or unavailable or unavailable due to supply shortages for semiconductor components as soon as the required parts become available module will be retrofitted as part of a service campaign.
LI82.00-P-073331 AUG21 - 213, 238, and 257 prior to facelift & 205 as of facelift intermittently after bus sleep the lower control panel (LCP) & upper control panel (UCP) may be inoperable codes U104587/U115587/U11A787 may be stored, update Audio/COMAND Operating Unit (A40/9).
Service Campaign 2021050013 AUG21 – 2019 213,238, 257 Emission Control Information label does not correspond with valid vehicle specifications may encounter issues during the vehicle registration or inspection process, dealer will replace emission label. Approximately 73 vehicles affected.
Recall Campaign 2021070032 AUG21 – 2020-2021 213, 222, 253, 257, 290 463 locking mechanism for the electrical connector on the side-impact crash sensors might not meet current production specifications, dealer will replace sensors. Approximately 138 vehicles are affected.
Service Campaign 2021090004 SEPT21 – 2021 205, 213, 238, 257, 290 right mounting support for the cross strut on the under body might not correspond to current specifications, dealer will treat with cavity protection wax. Approximately 1,163 vehicles affected.
Recall Campaign 2021080021 SEPT21 – 2021-2022 CLS, G, E, GT AMG automatic locking retractor function for the rear seat belts might not meet current production specifications, dealer will replace rear seat belts. Approximately 4,917 vehicles affected.
LI68.10-P-064592 SEPT21 – 213, 238, 257 noise on upper instrument panel, apply felt to center fill grille.
Service Campaign 2021100004 OCT21 – 2019 -2021 213, 238, 463 standard instrument cluster illumination may be momentarily interrupted, dealer will update HERMES SCN coding. Approximately 634 vehicles affected.
Recall Campaign 2021100006 OCT21 – 2021 223 control unit for occupant recognition might be deactivated permanently by the airbag control unit upon vehicle shut-down passenger airbag might be deactivated despite an occupant sitting on the front passenger seat, dealer will update airbag control unit software. Approximately 1,311 vehicles are affected.
LI46.35-P-071804 OCT21 – 213, 238 with code 801 fault code U045A00 "Implausible data were received from control unit 'Parking system'." stored in electric power steering control unit (N68), install new parking system control unit software and process fault codes in control units that communicate with it.
NHTSA ID 21V961 (MB # TBD) 2016-2020 118, 156, 167, 177, 205, 213, 222, 231, 238, 247, 253, 257, 290, 463 a leak may develop between the fuel rail and fuel injector due to trapped debris from the production process, dealer will replace the fuel rail and fuel injectors. Approximately 139 vehicles affected.
Service Campaign 2022010008 2/22 - 2021-2022 177, 118, 257, 213, 238, 247, 253, 167, 290 software for the MBUX control unit does not correspond with the latest series production configuration, dealer will update. Approximately 38,293 vehicles affected.
LI82.90-P-074451 2/22 – 213, 238 with code U88 interior temperatures greater than 40°C/105°F the ASCM control unit (A74/2) display flickers, perform a software update.
LI49.10-P-068745 2/22 – 213.x88/x89, 222.187/188, 217.x87/x88 power reduction from 4000 rpm actuator on exhaust gas flap does not operate correctly check Q-status of actuators if Q1 must be replaced, Q2 or higher PTSS case must be opened.
Getting a check right rear turn signal error in my 2021 E53 sedan. The lights all function correctly and it seems to be intermittent. Wonder if there is any sort of software bulletin for this?
Not that I am aware of. Warranty repair, suggest they check harness inclusive of ground point, and replace rear lamp (could be faulty circuit board diode).
Service Campaign 2022010001 2/22 – 2021/22 118, 167, 177, 213, 238, 243, 247, 253, 257, 290, 293 vehicles without the augmented reality camera (ARC), as disclosed at the time of sale functions are currently not enabled, dealer will retrofit and enable. Approximately 1,147 vehicles are affected.
Recall Campaign 2022040010 APR22 – 2021-2022 206, 213, 223, 232, 238, 257, 290, 297 vehicles that have a leather steering wheel with steering wheel heating, hands-off detection might not detect driver's hands are away from steering wheel when using the Active Distance Assist DISTRONIC system, dealer will update the hand detection control unit software for the Active Distance Assist DISTRONIC. Approximately 8,396 vehicles affected.
Recall Campaign 2021080018 JUL22 – 2019-2020 205, 213, 217, 222, 166, 292, 253, 172, 231, 463, 290, 190 vehicles may not meet current OBD software requirements. An emission recall campaign is being conducted to remedy the situation, dealer will update engine control unit software. Approximately 1,812 vehicles affected.
LI82.85-P-075044 JUL22 – 118,167,177,213,238,243,247,257,290 w/code 548/549 Apple Carplay cannot be operated by touchpad, on the affected iPhone: Settings > Accessibility > Touch > turn BackTap option off.
Recall Campaign 2022060007 JUL22 – 2018-2021 118, 167, 177, 205, 213, 238, 247, 253, 257, 293 rearview image might not be displayed after engaging the reverse gear. Instead, the central display would continue to display the existing image or black screen with a message indicating the inoperability of the rearview camera, update the rearview camera software. Approximately 126,179 vehicles affected.
This literally happened to me for the first time last night. It never happened before. Very strange to all-of-a-sudden occur. I did update the map software last week but I wouldn't think that would have created an issue.
I know this thread asks a lot of you, but could you please post the recall notice, if possible? I'd like to see if my car would be within the build period in question.
LI82.60-P-075292 SEPT/22 – 118,167,177,213,238,243,247,253,257,290 with code 548/549 after a bus sleep SiriusXM category changes, MBUX Multimedia System will be released in Q4 2022.
Service Campaign 2021060009 OCT22 – 2021 167, 213, 238, 257, 290 48Vbattery management system software might not meet specifications, update 48V battery control unit software. Approximately 58,546 vehicles affected.
Recall Campaign 2022080010 SEPT22 – 2019-2022 4matic 213, 238, 257, 290 transmission wiring harness might not be routed according to specifications, dealer will rework. Approximately 16,977 affected.
Recall Campaign 2022060007 JUN22 revision – 2018-2021 118, 167, 177, 205, 213, 238, 247, 253, 257, 293 function of the rearview camera might be impaired dealer will update the rearview camera software. Approximately 126,179 vehicles affected.
LI82.60-P-075292 SEPT22 – 118, 167, 177, 213, 238, 243, 247, 253, 257, 290 w/code 548/549 SiriusXM favorites lost, software update of MBUX Multimedia System in development.
I asked my Canadian service manager about this recall and he said they already did this here last year. Not sure if that's for real or not.
Interestingly (and likely unrelated to this recall?), the Mercedes ME app just sent me a notification that my system had been remotely updated, but for the life of me I can't find any record in the app that tells me what was undertaken. That's happened a couple of times in the past couple of years.
