E-Class (W213) 2016 - 2023
Anybody having issues with fueling?
Old Oct 26, 2016 | 06:40 PM
MB_SJ's Avatar
S500, E300, CLS500
Angry Anybody having issues with fueling?
Hello,
We have two 2017 E300 in the family, and we are having problems with fueling on BOTH vehicles. The pump constantly cuts off every 4-5 seconds and the only way I can continue filling is to put downward pressure on the nozzle. It's infuriating. I just want some gas. Take my money. It shouldn't take 15 minutes to fill up the tank.
I obviously tried different pumps at the same station, and had the same problem at other stations too.
Anybody experienced this? I know there is a recall on the fuel system cabling harness, but the fueling problem is mechanical problem. Grr. 98 miles on the odometer, and there is a recall.
I called the local dealer to schedule the recall service, and asked about this. The lady on the phone, and I am not kidding you, says "Those vehicles are designed to do that, you are using the pump is not compatible with your car."
My response - "Ok, I see. Thank you. I will just talk to the service advisor."
Old Oct 26, 2016 | 08:57 PM
PaulE550's Avatar
2015 E550 Coupe
Originally Posted by MB_SJ
Hello,
Try turning the nozzle upside down after you insert it.
Old Oct 26, 2016 | 10:01 PM
TestnDoc's Avatar
S550
No issues at all. I have been to many different gas stations.
Old Oct 26, 2016 | 10:02 PM
bizinsider's Avatar
2017 e300
Count me in...
Yes and it's driving me nuts! Works better at some stations than others. I can usually get it to work with a little finesse!
Old Oct 27, 2016 | 12:37 AM
heatpipe's Avatar
2017 E300 4MATIC
No issues either. 3400 miles and have fueled up across three states in the US. No problems at Mobil, Irving, and Shell gas stations if that's of any help.
Old Oct 27, 2016 | 01:30 AM
outie's Avatar
2011 M3 ZCP, 2022 Porsche Taycan GTS, 2018 Tesla Model X, 2023 McLaren 720S Spider
I've had these issues with most of my cars - Porsche Cayman S, BMW M3, 535i. It's like I had to constantly fight for the correct "position". Twist it left, twist it right, don't insert too much, upside down, 90' degree, etc. (omg what am I talking about now... that sounds so.. weird). I ended up checking how many gallons I've filled to determine whether the tank is full.
Some gas stations are worse than others. Porsche dealer told me they had no issue at the 76. Back then I always filled at Chevron. So it's not really a defect but there's just no fix for it.
Old Mar 20, 2017 | 06:56 PM
ipppsssssy's Avatar
W213
I absolutely hate this about my W213! Driving me nutts!
Old Mar 20, 2017 | 07:05 PM
joebe's Avatar
2017 E 300, Toyota Land Cruiser
Only once in 4500 miles.
Joe
Old Mar 20, 2017 | 07:35 PM
c4004matic's Avatar
17 E43; 21 GLS580
Hello,
The c class has the same issue. Its due to the US unleaded fuel gas nozzle. Instead of making an adapter of a concentric design, the mercedes adapter forces the nozzle to the lower portion of the fuel pipe. This creates enough turbulence for the pump to shut off. 7The partial solution is simple, do not insert the nozzle all the way in. Insert it only enough so it doesnt fall out. This works most of the time.
Old Mar 20, 2017 | 08:50 PM
makris0000's Avatar
No issues on mine for the past 2350 miles.
Old Mar 21, 2017 | 12:16 AM
jgs1564's Avatar
2018 E400 Coupe
I have the same problem almost every time I fill gas. It's infuriating to have to hold the nozzle down for so long while refueling. As other E300 owners mentioned on this forum, some stations are better than others. But 95% of the time, I fill from the same station near my house.
Old Mar 21, 2017 | 12:20 AM
joshg1001's Avatar
2017 E300
I have not had a single problem, this is with the california vapor cap too.
Old Mar 21, 2017 | 11:41 AM
johnmc1's Avatar
2017 300E
No issues after 3 fill-ups.
Old Mar 21, 2017 | 11:50 AM
ADD0514's Avatar
E300 P03
You can find a few more suggestions here...I still have the problem since starting the thread - But not as often, however.
https://mbworld.org/forums/e-class-w...-gas-pump.html
Old Mar 21, 2017 | 04:52 PM
Mbracer26's Avatar
Past 03 SL500,03 C240, 07 E350, 07 ML350, 10 ML350,11&14 E350 X2 2017 E300, 2017 C350e & 2000 S500
I realized this recently as well, I had to push in the nozzle couple times to get it to stay. another annoying downside of this car
Old Mar 22, 2017 | 05:53 AM
silberrosa's Avatar
As C4004matic also mentioned, not inserting the nozzle all the ay but still fully secure is the key. Works EVERY time now.
Old Mar 23, 2017 | 06:57 PM
mitul316's Avatar
2017 E300 4Matic
This is exactly what I do, I don't have issues and I am almost at 25k miles now.
Old Mar 26, 2017 | 06:06 PM
MAmendola's Avatar
2014 ML350 Bluetec, 2016 GLC 300, 2023 Corvette, Z51 Stingray
I have owned a 2006 ML350, and 09 ML350 currently own a 14 ML350 Diesel, and a C300. Have never experience this.
Old Mar 28, 2017 | 04:15 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
i have the same issue, but turning nozzle 90° works fine
