E-Class (W213) 2016 - 2023
E43 aftermarket wheels
Old 07-29-2017, 01:36 PM
mdot949's Avatar
2016 C63S AMG
Do any of you fellow E43 owners have an aftermarket wheel setup on your car? I'm still on the hunt for a good set but I am having a hard time finding the perfect offsets and other examples to reference.
Please share your specs and experiences if any
Old 07-29-2017, 01:54 PM
getmercd's Avatar
Mercedes Benz C43 AMG
Subscribed to this. My boy is looking for wheels for his E43 lol. Both your cars look great! Any performance work done?
Old 07-29-2017, 02:41 PM
ua549's Avatar
Here are wheel specs.
Old 07-29-2017, 02:57 PM
mdot949's Avatar
2016 C63S AMG
Thanks for the link! I have all the OEM specs and everything already though. What I am looking for is more info about anyone who has fit a set of aftermarket wheels and what width/offset they went with, and how aggressive (or conservative) the fitment is.
The only set that I was able to test fit was the HRE FF01, the specs were as follows:
20x9 et.25 245/35/20 front - The fit was fine, and it cleared the front brakes.
20x10.5 et 35 275/30/20 rear - The fit was way to aggressive and the poke was to much for my liking.
Ive seen a good amount of w213 non-amg models with aftermarket wheels but I haven't seen many E43's. So its a bit tough to find the exact specs and fitment that would work.
Old 07-29-2017, 03:18 PM
mdot949's Avatar
2016 C63S AMG
Thanks! No performance work has been done, I am pretty content with it OEM for the time being. In the future after more parts and things come out then I might be interested, but who knows
Old 07-29-2017, 10:25 PM
Former Vendor of MBWorld
Mike@Vossen's Avatar
AMG
You can build yours at www.vossen3.com and see what your E-class will look like on Vossen Wheels including our Forged Lineup.
Direct Link Below
http://vossen3d.com/?scene_Mercedes_...Sedan_AMG_2016
As an example here is our Vossen Forged HC-1
On Monday I can review specs.....
Old 07-31-2017, 12:45 PM
Registered User
roger23's Avatar
2010 E550 / 2012 ML 550
The Tire Rack seems to have a good selection....
I will need 4 for the winter, for my E43.
Old 08-02-2017, 02:09 PM
getmercd's Avatar
lol I hear you. My buddy just had his dyno tuned and it is sweet! I was just watching the video on youtube hah can't get enough
mdot949 (08-02-2017)
Old 05-19-2018, 05:35 PM
eas43's Avatar
'17 E43
Any updates from folks with some decent aftermarket wheels?
Old 05-20-2018, 03:43 AM
vic viper's Avatar
S213
Non AMG and the E43 share the same chassi specs, the wheels used for a non AMG can also be fitted to a E43.
The E63 however is a different deal.
Old 05-20-2018, 10:36 AM
eas43's Avatar
'17 E43
Vic, what width/offsets did you go with? Your wheels look perfectly flush. How's the ride been in 21"
Old 05-20-2018, 11:54 AM
vic viper's Avatar
S213
9x21 ET40 (with 5mm spacer making ET35) and 11x21 ET50, works really well, not much harsher than the stock 20"
Old 05-20-2018, 12:29 PM
Cao Black's Avatar
2015 ML350+2021 E350
FYI, here is another site where you can see the effects of changing wheel size and offsets (with or without spacers). Depending on your budget, wheel makers will do custom orders. Good luck.
https://www.willtheyfit.com
Old 05-22-2018, 01:07 AM
G3710's Avatar
17 E300
245/35/20 20x8.5
275/30/20 20x9.5
tires Hankook evo2
offset 45 front and rear
Old 05-22-2018, 01:26 AM
G3710's Avatar
17 E300
Nice set up, looks amazing!
Old 05-28-2018, 06:09 PM
dayjob3's Avatar
C350 coupe
Did you add the front 5mm spacer to clear the breaks or was is just for asthetics?
Old 05-28-2018, 08:06 PM
jhpmbusa's Avatar
2021 M550i
Which brands even make wheels as strong as oem? I am very hesitant on aftermarket wheels after going through a few sets in the past. Every pothole would bend the rims...
Old 05-29-2018, 01:12 AM
vic viper's Avatar
S213
Asthetics, I ordered the custom wheels before the car had arrived so I was 5mm.s out on the fronts.
dayjob3 (05-29-2018)
Old 05-29-2018, 10:57 PM
dayjob3's Avatar
C350 coupe
I ordered your wheels in the same specs. Will post pics once they arrive. Thank you for the feed back. INVALUABLE!
EnigmaAW (06-02-2018)
Old 06-06-2018, 12:22 AM
dayjob3's Avatar
C350 coupe
Wheels are here and mounted. Needed a little tweaking but damm I like this design.
Old 06-06-2018, 12:26 AM
dayjob3's Avatar
C350 coupe
Still need to sort the front suspension
Old 06-06-2018, 04:15 AM
vic viper's Avatar
S213
Wow, looks great, kinda regret not going for the silver finish
Old 06-06-2018, 06:58 AM
hyperion667's Avatar
Received 3,416 Likes on 2,855 Posts
2012 CLS63
I have wheels for sale
Old 06-06-2018, 05:26 PM
dayjob3's Avatar
C350 coupe
Thank you. You nailed the rear fitment. It couldnt be better. I should mention that my rear wheels are 10.5 not 11 inch wide. The fronts should have been et 35 because they were just touching the calipers. Instead of ordering 5 mm spacers for the front, I just shaved the calipers down 1mm were they were touching only and re painted.
I also am running eibach lowering springs. I have the AWD but purchased the RWD springs. As it sits, the front is an inch too high in my opinion. Will probably cut half or a full coil. Still waiting for things to settle. But thank you again for being the guinea pig.
Old 06-07-2018, 03:59 AM
vic viper's Avatar
S213
Sounds strange, the fact that you have 4-matic should make it lower up front due to the heavier front end.
Quick Reply: E43 aftermarket wheels
