Multibeam issue?
My car was built in the spring of 2017 and has multibeam ILS. I noticed already in the summer that people occasionaly flashed their lights at me, and as far as I remember the high beams were not on (the blue light symbol was not on) then.
On my previous W205 (2016 model) with ILS I dont recall people flashing their lights at me.
Does this seem to indicate something is wrong with my lights?
Best regards
The multibeams are very bright and the people flashing their high beams are ususally in an older car with crappy haologen lights.
Also an older high beam, halogen or xenon, are easy to spot over the horizon when it is turned off,
but the multibeam just diverts the light pattern from the oncoming cars making some of the oncoming traffic think that you still have your high beams on.
Its all a matter of ignorance really.
After replacement I rarely got flashed (supporting my view that the replaced hardware cured the problem) and when it happened, I'd put it down to what Vic says - each headlight has not only the two DRL stripes lit up but another three large lights illuminated all the time. Oncoming traffic can easily mistake that entire light unit lit up like a Christmas trees as the car having main beams fully on (which is does, just not shining right at them if the system is working well!).
As nights have drawn in now I've had active main beam on during a couple of runs and it seems sluggish again and I've been flashed a few times again. However it's not as bad as it was and I can see it working correctly at least some of the time. On mine, now, the issue seems to be late boxing of traffic. I see the car come round a bend, car doesn't react for two or three seconds. In that time I'm giving that car full beam and they flash me. By the time they are flashing though, my car has reacted and boxed them so I guess they think I switched off main beams!
If mine gets worse or I'm getting flashed a lot every journey I'll be asking for the software to be reinstalled or the control unit to be replaced as that worked perfectly before. No idea why or even how the system can degrade in such a manner and I can't say for certain mine really is worse again without some more trips to check. However, I know 100% the system was not working correctly, replacement hardware/software cured it so if you've problems I'd suggest you try and force that root with your dealer (though do consider what Vic is saying and check to see if the boxing of traffic feels slow/late/out of phase to you first).
I have had the thought that the lights are bright and oncoming traffic assume head lights are on. Could be tje case!
On the w205 which had ILS (not multibeam) I would notice a black rectangle follow a car infront of me as I drove behind it and the rectangle would move left or right depending on how the other car was driving, constantly putting the car in "shadow".
Now having multibeam I dont notice a black rectangle following a car infront of me and I am hoping I am not blinding them. Does other people with multibeam see the dark rectangles?
For me, it’s the most outstanding innovative feature of this car.
I am driving the Coupe version but it was equally effective on the w213 I had before.
I was just informed that the system struggles if there is a "wire fence" between the lanes and so the manual suggests turning off the high beams in such areas. It does make sense because i dont remember cars flashing me as mucj when ive been driving on roads without the "wire fence".
