E-Class (W213) 2016 - 2023
Dynamic Select S213
Old Jan 10, 2018 | 08:34 AM
HappyJack's Avatar
E Class S213
Dynamic Select S213
Hi all,
Just ordered a S213 220D SE 4Matic. I haven't specified Airmatic (although now I wish I had). Should be arriving in March
I have a couple of questions if anyone can answer for me
Does the Dynamic switch only alter the gearing and steering or does it change the suspension damping settings like BMW VDC. The description from Mercedes seems to say this is the case but I can't get a definitive answer. I am not bothered enough to go back to the dealer!
AGILITY CONTROL suspension with selective damping system and lowering - is this all done automatically from the Dynamic Switch or can you change the suspension settings without changing the engine characteristics? ie have sport engine settings but with comfort suspension on the individual settings
AIR SUSPENSION with level control on the rear axle - I take it this just self levelling and is all done automatically
Old Jan 10, 2018 | 09:44 PM
jhpmbusa's Avatar
2021 M550i
Just picked up my 2018 E300 last week. Havent had a chance to test it yet, but if I go to individual settings, I have the option to adjust engine, steering and ESP (suspension) from comfort, sport and sport+.
Havent tried it yet tho.....
Old Jan 11, 2018 | 09:06 PM
Szamot's Avatar
E400 Wagon
Originally Posted by HappyJack
Hi all,
Yes it does, as far as I can tell. If you set everything up to Sport+ the car is track ready - or close to it. It certainly is a lot more fun to drive. Having said that when you switch it back to Comfort or Eco the car raises up a bit and is a lot smother.
Old Jan 12, 2018 | 01:21 PM
The_Judge's Avatar
2018 E400 Coupe
Note that MB recommends that you drive in Comfort mode for the first 1000 miles to break in the car properly.
Old Jan 12, 2018 | 01:31 PM
Szamot's Avatar
E400 Wagon
It's at 6200 km so it's red line city and petrol grunt!
Old Jan 12, 2018 | 01:48 PM
HappyJack's Avatar
E Class S213
A track ready mobile dog kennel - I like the sound of that
Old Jan 12, 2018 | 01:49 PM
HappyJack's Avatar
E Class S213
Thanks Gents
Old Jan 12, 2018 | 02:33 PM
78degrees's Avatar
2018 E63S
Does it actually say ESP (suspension) or just ESP?
ESP is also known as Electronic Stability Program and has nothing to do with suspension.
Old Jan 12, 2018 | 05:49 PM
jhpmbusa's Avatar
2021 M550i
Read through the owners manual through the command system. Yes Sport and Sport + will tweak the suspension settings to make it more "Accentuated" in terms of oversteer and understeer inputs. I think only the 2018 models might have this? Go into your individual settings in the dynamic mode.
Engine has the usual eco , comfort, sport sport +, Steering is comfort or sport, ESP is comfort sport and sport +. Let me know what you find!
Old Jan 12, 2018 | 07:48 PM
Proeliator2001's Avatar
E220d
Hi all,
Mercedes are incredibly misleading with how they describe this system. It is not adjustable or selectable in any way by the driver, it merely firms up under certain rates of compression/extension. It basically allows for a soft ride without wallow. My old w212 had adjustable suspension and I genuinely thought this new one did too but it was mere placebo. The car is on 19s so it's way stiffer than my old one to start with. The difference between comfort and sport that in my head made the car a bit stiffer is just down to the steering weight change.
I thought the agility control with lowering was only on AMG line cars (well in UK market at least), did you option it? What size wheels you spec? If I had my time again I'd have gone 18s.
Old Jan 13, 2018 | 09:09 AM
HappyJack's Avatar
E Class S213
SE with 17" wheels. I am built for comfort these day - plus there are more potholes then road where I live
The spec for the car says the following - as standard.
Air suspension with level control on the rear axle
The specs for the cars seem to have changed between 2016 and 2017 with Direct Control suspension being replaced by Agility Control suspension
Old Jan 13, 2018 | 12:31 PM
jhpmbusa's Avatar
2021 M550i
Correct, the description changed from 2017 and 2018 as far as i know. I brought this up in my other post as well. and keep mentioning "2018",
Old Feb 12, 2018 | 03:32 PM
fizad99's Avatar
2017 e300
what does sport and sport + do to the ESP? i can't tell the difference when i switch between these while driving.
Old Feb 12, 2018 | 03:33 PM
fizad99's Avatar
2017 e300
Old Feb 12, 2018 | 04:33 PM
jhpmbusa's Avatar
2021 M550i
So when you make these adjustments, its gets saved onto you "INDIVIDUALIZED" settings, which is on top of sports+. Make sure you are on the I* setting to notice the difference. Please let me know if this works for you!
Old Feb 12, 2018 | 06:17 PM
fizad99's Avatar
2017 e300
Hi, yes i know how to set it on individualized, i just dont know what changing ESP to sports or sports+ does? what does it do? The engine on sports+ makes the rpms higher i feel the extra power, the sports in the steering wheel makes it tighter, but what does sports on ESP do???
Old Feb 12, 2018 | 07:43 PM
jhpmbusa's Avatar
2021 M550i
It should make the suspension feel track-ready like some say. But all jokes aside, try going over the same usual bumpy/pothole roads that you know of and see if it feels different. I've noticed if you set in on cruise control on same roads you take everyday, you will be able to tell the suspension is a bit more stiff. Let me know what you think!
