Windshield Washer Fluid
Windshield washer is low and read the manual which said I need to use MB blended fluid, otherwise some damage to plastics may occur? This sounds like BS. How can MB windshiled washer be any different than every other washer out there? But before I throw in the stuff I bought from the gas station, figured I'd ask here.
Thanks in advance for any replies.
Actually... when I refill it on my own I use RainX washer fluid and haven't seen any detrimental effect. However, i seem to recall a thread on here that indicated that using the wrong fluid can affect the sensor used to determine if the fluid level was low.
I have been using RainX in my MB vehicles for over 20 years, with the exact same problem, which magically, seems to cure itself.
Whenever I fill up the reservoir with Rain X for the first time, yes, I always get the 'low washer fluid' warning light coming on.
I go to my dealer, and they replace the sensor.
From that point on, over the next few years, although filling the reservoir subsequently with many many jugs of Rain X, the light never comes on again.
The next new MB vehicle I get, its the same process all over again....
For some reason, replacing the factory sensor, with the MB parts dept sensor, seem to fix the problem permanently.
MB claims its the same part at the factory, and I have contacted Rain X, and they have no explanation for this phenomena, who says there should be no detrimental effect if used in MB vehicles.
I really cannot understand why its only the original factory sensor which causes the problem, and not the replacement sensor installed at the MB dealer, using the specified MB part.
So years ago, I gave up trying to figure out the answer, and now I simply go through the ritual of replacing the factory sensor once, then continuing to use Rain X happily thereafter, with no 'low washer fluid' light coming on thereafter.
I must have been lucky thus far.....
I have always used Rain X on my many MB vehicles, and never experienced wiper blade chatter....
I put Silver Wax water beading treatment on my windshield with my new E, and have had no problems....
Cars are a mystery........
https://www.classaction.org/rain-x-lawsuit
I seem to recall that some complaints were about the windshield sensors...the ones that turn the wipers on automatically when rain is sensed, rather than the low washer fluid warning sensor. I don't use either RainX or Aquapel, so I haven't researched further, but I can state that I have experienced wiper chatter and had the dealer adjust the blades.
I just bought a ‘15 ml 350 (really enjoying it) and wouldn’t think to fill it with rain X.
I’ll better buy the Mercedes concentrated liquid for 20 bucks, and you can buy it online from Walt mart or amazon. Or better yet I’ll go to the dealer and ask if they can fill it (hopefully for free).
Removing the fender to DIY troubleshoot the pump/sensor is low on my priorities, and taking a car worth $500 to the dealer or an indie is out of the question.
Given all the negative discussion across several sub-forums on this topic, the Mercedes "S" fluid concentrate is about the only OEM Mercedes consumable part that I use religiously on my W212.
nothing comes out and my levels are full.
Not sure if clogged, or something electrical wrong
