what are pros on cons of 20inch wheels against 19 inch for Amg E53 ? Thanks
arnsbrae
close
- Join DateApr 2014
- LocationUnited Kingdom
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveWeekend: 2010 SL 350 r230 Weekdays: 2018 E220d Coupe
Liked:31 Times in 27 Posts
Quote:
The ride is fine.Originally Posted by visualguy
The usual - a harsher ride and higher risk of damage from potholes.
Quote:
If the ride on the E53 is the same as on the E43, then it will be pretty harsh even with the 19" - the suspension is quite stiff even in the comfort mode. The 20" will make it even harsher, and it will make the rims more vulnerable to damage from potholes and curbing. There are no pros, just cons (other than maybe cosmetics).Originally Posted by arnsbrae
The ride is fine.
Wolfman
Super Moderator
close
- Join DateMay 2002
- LocationLand of 10,000 lakes
- Vehicle(s) I driveAMG GTC Roadster, E63s Ed.1, M8 Comp. Coupe
Liked:3,630 Times in 2,222 Posts
The difference in ride quality between 19” and 20” will be minimal at best. People always over emphasize that.
The type and brand of tire has a far more significant impact. A great non run flat tire like the Michelin PS4s will do the job.
I have to to admit that I haven’t driven a E43/53 and assume it will be between a mushy E300 and a super stiff E63s. That car will loosen your fillings in race mode
The E53 will calibrated somewhere in between on purpose and the I recommend the 20” with good conventional tires and adjusted tire pressure.
I have had cars with 19” & 20” rims. Zero difference on pothole damage IMO
Quote:
I have driven the E43 with the 19" wheels and the standard RFT tires. The ride is pretty harsh in comfort mode - you feel everything on the road. It's a shame because the car has air suspension which should have enabled them to provide a more comfortable comfort mode, while retaining a stiff sport mode. The air suspension is kind of wasted on that car... This will be a disadvantage of the E53 as well if they kept the same suspension tuning.Originally Posted by Wolfman
Thank you all , much appreciated.
Quote:
I ordered a 2019 E450 today and was determined I wanted the 19" wheels. The dealer really really pushed me to not spend more money and get the 18" wheels for the reasons listed above. When you consider tires are expensive puppies, you don't really want to be putting new rubber shoes on the car sooner than you need to.Originally Posted by infamily
Wolfman
Super Moderator
close
- Join DateMay 2002
Quote:
Apples to oranges comparison. Sounds like the E43 or E53 isn’t for you. Air suspension doesn’t mean more soft or comfortable on any AMG variant. They are completely different in their calibration to a non-AMG. Originally Posted by visualguy
Our E63s has air suspension and it has zero give. It will make look the E53 like it’s riding on a cloud.
Not saying it’s good or bad but it is intended.
Run flats are are also adding noise and roughness to a ride. The thicker sidewalls can also contribute to easier rim damage.
