E-Class (W213) 2016 - 2023
rear bumber sticking out a bit
Old Jul 23, 2018 | 05:58 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
rear bumper sticking out a bit
on the pic you see on the left how it sticks out and on the right after I pushed it back in.
but it always pops back out again - this happes on both sides.
it's not a very huge deal, but can't say it's a very good finish either..
anyone else have the same problem ?
Old Jul 23, 2018 | 07:14 AM
vic viper's Avatar
S213
My guess is that youve been hit from behind, check for damages on the bumper.
Old Jul 23, 2018 | 08:10 AM
Egonvdv's Avatar
that was my guess as well, but no damage at all...
Old Jul 23, 2018 | 09:56 AM
mister__p's Avatar
E250
With the new plastic bumpers and high quality paint you get these days, you don't always get any damage after a hit. I've been hit in the rear twice this year and on both occasions, neither hit left any marks. On the second occasion, the offenders front bumper was crumpled whilst mine was dislodged a bit but the paint was completely untarnished.
i recall you had a number of issues with brake vibrations - maybe MB didn't assemble the car properly after checking for issues ?
Old Jul 23, 2018 | 10:23 AM
Egonvdv's Avatar
so if I've been hit, coud there be "internal" damage? radar/camera etc work fine
Old Jul 23, 2018 | 11:52 AM
konigstiger's Avatar
'71 Pinto
Wondering if this is a recurring problem 212 had this and it was corrected with modified part. See attachments.
File Type: pdf
File Type: pdf
Old Jul 23, 2018 | 11:56 AM
Egonvdv's Avatar
thanks for the info! will discuss with dealer
Old Jul 23, 2018 | 05:58 PM
parkwood's Avatar
EQE 500 4MATIC replacing EQC 4matic AMG line P
Well our fellow "citoyens" here think nothing of using the car in front or behind as an automatic stop when parking. In Paris I have seen cars literally be pushed back by the manouvering car to make a space big enough for them to squeeze in aided by the fact many owners leave the handbrake off to facilitate such a manouvere! I am in awe of many french drivers parking skills but never park at the side of the road to avoid my car being bounced off by another car squeezing into a space😉
So Vic could be right. But the info 're the w212 problem was interesting.
Old Jul 23, 2018 | 06:06 PM
ua549's Avatar
+1 All cars in Rome have smashed corners.
Old Jul 23, 2018 | 06:13 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
As always, a good call from konigstiger. IIRC the flexing issue was worsened if the bumper got hot from direct sun exposure.
Old Jul 26, 2018 | 09:30 PM
Knivels's Avatar
2011 E350 Luxury, 2017 E300 Sport
I actually got a whole new bumper from that campaign for my 212.
Old Jun 23, 2020 | 12:25 PM
SunnyC257's Avatar
2021 CLS 400d
I've got EXACTLY the same problem, on the same side. The right hand side is flush with the tail light, but the left hand side is sticking out, and if I push it in with my hand it just pops out again.
Has anyone found the solution to this on W213?
Old Jun 23, 2020 | 12:42 PM
'71 Pinto
Bumper may need to be reworked under warranty.
File Type: pdf
Old Jun 23, 2020 | 01:47 PM
haibieb's Avatar
2026 GLE 450 (Black on Brown Saddle)
Hi. I had the same issues on two of my E Classes. In both cases, the tail lights assembly have to be removed and re-install a new retaining clip to hold the bumper piece from the inside. For some reason this problem is prevalent on E's and CLS' The process takes about an hour and should be covered under warranty depending on the age and mileage of your vehicle.
Old Jun 24, 2020 | 07:11 AM
dudley07726's Avatar
2023 BMW M340i, 2025 MB CLE53 AMG
I have the same issue except with my right front fender. MB will repair it under warranty at my next visit.
Old Jun 24, 2020 | 03:45 PM
Mike__S's Avatar
Top Answer: 1
20 E450 Luxury
+1
My 2017 CPO rear bumper corners were flexed outward in the exact same manner....dealer r&r bumper and re-alighned, It is better but not perfect.
These are large, thin plastic surfaces and I imagine they would distort due to excessive heat alone. Getting gently tapped is an equally possible factor as well, but I remember in London several years ago a particular hi-rise was acting as a 'tense' for the sunlight and several cars were damaged, Mirrors melted, bumper corners distorted distorted, etc. Just about any plastic surface was being damaged in particular parking spots during the day. City had to make no park zones,
Old Mar 24, 2021 | 10:08 AM
Kom072692's Avatar
2017 e300 4matic
Same issue
Just took it to the body shop that worked on it before and said they come from the factory like that. Mercedes made in america are just lacking
Old Mar 24, 2021 | 01:05 PM
ua549's Avatar
E Class is not made in the US.
Old Mar 24, 2021 | 01:08 PM
Kom072692's Avatar
2017 e300 4matic
well mercedes as a whole then is slacking
Old Mar 24, 2021 | 01:56 PM
Mike__S's Avatar
Top Answer: 1
20 E450 Luxury
I’ll add a bit to my earlier post. The problem is possibly a combination of tooling design, mounting design and everyday use factors.
More to the point, let me ask why we attempt to call flush fitting end panels ”bumpers”. This notion alone may well be the true problem! Think about it.
My best guess is that if the bumper cover is pushed ever so lightly in parking (by either vehicle) the corners can be poked out “ever so slightly”. It is possible to dismount the cover and tweak the mount points back into position.
A second possible contributing factor could be the cover comes off the tooling too quickly and distorts ever so slightly, leaving it pre-tensioned when mounted to the car. It would then create this pre-tension at installation, a stress factor that can be seen by the tips of the corners sticking out. Especially if just ‘touched’.
Not having seen the underlying parts myself, it is not possible for me to suppose a true picture of the situation...either or both explanations are equally likely. Occam’s Razor points to my “best guess” of a perfect fitting rear cover simply getting touched ever so gently at some point.
I can say, in being both American (since 1742) plus well immersed in German culture, speaking the language fluently, that I would hesitate to lay the problem to some preconceived notion of underlying cultural or corporate norms. Not an approach conducive to understanding or solutions, even when true.
In any event, it is a known issue and in my case was repaired free under warranty.
