Any windscreen washer recommend?
https://www.ebay.com/itm/39521555019...3ABFBMwpKv8ZNk
In other words pure profit for MB and money taken out of your pocket by your SA!
With regard to the class action lawsuit against RAIN-X.
This case was limited to a small class of people who used RAIN-X before 2015, mainly BMW's, almost 10 years ago. The problem was that RAIN-X had chemicals that caused the sensor that monitors the reservoir level of the washer fluid to malfunction. The law suit alleges that when there is fluid in the reservoir there is an electrical current between the two probes in the sensor in the reservoir. When the fluid level drops, the electrical current is broken and a light indicating low fluid level appears as a warning in the instrument panel. There were chemicals in RAIN-X that prevented the electrical current and false warnings indicating low fluid levels. Those sensors needed to be replaced.
Again this problem was limited to a minute number of cars (less than 6,000 - mainly BMW's) who used this monitoring system. The suit was settled by granting $250,000 to the plaintiff, which was between $20 and $200 to each member to cover the cost of replacing the sensor.
If you car had a different way of monitoring windshield washer fluids, which 99.9% of cars do, RAIN-X was not a problem.
see: https://webservices.courthousenews.c...f6347c45d2.pdf
and
see: https://www.classaction.org/media/ta...-inc-et-al.pdf
The problem is made worse by the commonly available fluids in Western Canada. In some kind of supply optimization genius move, the gas stations have decided to run one product. More or less it is just winter washer fluid. If you're in an area where there are a lot of bugs it's incredibly frustrating. It doesn't clean bugs off the windshield, rather it smears them around in an awful way. The ceramic does make it easier to remove the bugs...but only if the fluid does its job. When I can find summer, or bugs guts compatible fluid, then it cleans quickly and easily but leaves a very small remnant of fluid that provides a streak of sorts. Not in a nice way.
So...if you don't have bugs, the ceramic is something I would say has benefits that outweighs the negatives. But in a bug area it produces a 'wash' between having the ceramic or not. Can't comment on winter just yet.
That said, in one aspect of my professional life, I do know a bit about glass. Here's the bottom line....IT'S WASHER FLUID!!! LOL. Buy a good quality one and you'll be fine.
